Remove all Ulead Files
Lanni
motherboard: Lenovo
processor: Pentium Dual Core T4300
ram: 3gb
Post by Lanni »
When I puschase the Diamond video capture device, it came with Ulead VideoStudio 10 SE.
This program would not work in Windows 7
I tried to uninstall it, but I guess I did not do it correctly.
A file is still running. It has to do with Windows color sheme.
After starting computer up, a window appears saying something like Windows color sheme has been changed to 7 basic.
Because (and I can't recall all the words, but it has to do with a Ulead file still running)
I would like to completely remove any Ulead files still occupying space in the computer.
Hopefully you can help me remove them. If I knew where the file might recide I could go into the registry and delete it.
Re: Remove all Ulead Files
Post by Trevor Andrew »
First I did not know that Ulead/Corel affected the Windows Colour Scheme
If VS 10 is your only Ulead/Corel program then purging your pc should easier.
I do not use Windows 7 so don’t know exactly where things are installed, besides not many will have VS10 and W7.
I have some details of re-installing VS 10, I think for XP.
reinstalled VideoStudio 10
1. Launch Windows Explorer and go to "Tools > Folder Options > View" to check "show hidden files and folders";
2. Purge/delete all the files in these folders: "C:\Windows\Temp" "C:\Documents and Settings\[User Name]\Local Settings\Temp" (for WinXP);
3. It is safe to delete all contents of these folders. However, leave any files you can?t delete for now;
4. Delete these folders/directories: "C:\Program Files\Common Files\Ulead Systems" "C:\Program Files\Ulead Systems\Ulead VideoStudio 10.0" "C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead VideoStudio\10.0" "C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc" (for full versions);
5. Go to "C:\Program Files\InstallShield Installation Information";
6. Delete the folder "{E188D820-1218-4E28-8BCA-91134C3664C2}";
7. Go to Start-->Run;
8. Type "regedit" then "OK";
9. Go to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Uninstall;
10. Locate and delete the identity enclosed in curly brackets that corresponds to Ulead VideoStudio 10: "{E188D820-1218-4E28-8BCA-91134C3664C2}";
11. Go to "HKEY_CURRENT_USER\Software\Ulead Systems\Ulead VideoStudio";
12. Delete the folder "10.0";
13. Go to "HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Ulead VideoStudio";
14. Delete the folder "10.0";
15. Close Regedit and restart Windows;
16. Reinstall Ulead VideoStudio 10.
Note: You need to have "Administrator" privileges on your computer. "Limited" or "Guest" accounts won't let Ulead software install or run properly on your computer.
In addition I would search the pc for all Ulead, VideoStudio, SmartSound, vstudio,
Hope this Helps
Take care
Lanni
motherboard: Lenovo
ram: 3gb
Post by Lanni »
Ok before doing any of your instructions except for going into the program files I found that most of the program files still existed on the hard drive. I decided to do a reinstall of the software. But when I started it an option came up that said I could do a removal of all existing files. so I did that an rebooted and the color sheme notice did not appear anymore. So looks like I fixed it. Hopefully. Thanks again for your reply and offering some help.
