VOB files mismatch
jaysto
motherboard: Acer Aspire X1420
processor: 2.80 gigahertz AMD Athlon II X2 220
ram: 4GB
Video Card: NVIDIA GeForce 6150SE
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer AL1916W
VOB files mismatch
Post by jaysto »
Hello
I have two video files VTS_01. and VTS_ 02, they are VOB files roughly 30 min in duration. The files have been copied from a DVD RW disc. the content is a TV recording. I have been trying to copy them into Corel Pro 3 for editing purposes. all I get is file mismatch (unable to open file , file mismatch).can anybody explain why this is, and how i can copy them to Pro3.
Any help will be most appreciated
Thank you
jaysto
Jaysto
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: VOB files mismatch
Post by skier-hughes »
How are you trying to get these files into video studio, can you tell us the steps you are taking.
You should, if I do this right from memory, import digital media, navigate to the dvd disc and click on the file. May be wrong as I can't get to VS from this computer :)
The even simpler answer, if the above does not compute, is that VS cannot use VOB files in that same format... You either import them as described above, or you could even try changing the .vob extension to mpg...
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
I normally change the .vob to .mpg and have never problems in VS
jaysto
ram: 4GB
Post by jaysto »
Thank you all for your replies I shall try changing the file name. Now the file names are VTS_01 VOB and VTS_ 02_ VOB. Will I just change the name to MPEG...? and then by right clicking the files and clicking rename.
Many thanks for all help
jaysto
Jaysto
Post by BrianCee »
I'm not sure whether you have just not typed the names of your files correctly or whether they are actually called what you have typed - if they have come from a standard DVD they should be called VTS_01_1.VOB and VTS_01_2.VOB - that is not what you have typed - but is it what yours really are ??
If yes then when you rename to mpg you just simply change the extension so that they become VTS_01_1.mpg and VTS_01_2.mpg.
If no and your original post is correct - where did these files come from ?
jaysto
ram: 4GB
Post by jaysto »
Ok Brian
Thank you for clearing that up I shall give your suggestion a try and see how I get on. In the meantime Trevor has also sent me a suggestion so I will try that as well.
Jaysto
Jaysto
Post by BrianCee »
OK - I suggest you try Trevors suggestion first - as the normal way - then if that does not work try the re-naming.
jaysto
ram: 4GB
Post by jaysto »
Brian Trevor,
Sorry to be a nuisance but do I rename all the vob Files, there are seven in all. I have a picture but cannot find a way if inserting it.
Thank you
Jaysto
Jaysto
Post by BrianCee »
Yes indeed if you want them all in VideoStudio - but are you sure all 7 are VOB files - thats quite a big video - in a DVD folder there are a number of other files with similar names but do not have the .vob extension (they may be BUF or IFO) - you only need the vob files in VS - so you only need to rename vob files.
just a warning - if you are going to burn the result to a DVD then 7 .VOB will not fit on a standard DVD - your talking dual layer at least.
Post by Trevor Andrew »
Hi Jack
This may help.......................
Jack please rename the highlighted files to :-
VTS_01_1.mpg
VTS_01_2.mpg
You should then be able to insert them to video studio
jaysto
ram: 4GB
Post by jaysto »
Ok Gentlemen,
I have renamed the VOB file exactly as described, I then imported VTS_01_1.mpg. onto the time line and yes it played ok. Spured on I tried inserting a title at the begining of the clip. Clicking play from the start of the clip, Pro X 3 said No...! and promptly crashed,saying ProX3 had a problem and had to close down the programe simply refused to do anything. I tried this 2/3 time exactly the same thing happened.
Now I have tried to restore the mpg files to the original VOB format using system restore to the previous day, the files remain still as Mpg files, so i have now to find a way of being able to edit the mpg files. I still cannot find out how to insert a picture into this reply
Any suggestions gladly welcomed.
Thank you
jaysto
Jaysto
To insert, upload, an attachment, when you're typing in your reply, look down at the bottom left. You should see 2 tabs, Option and Upload Attachment. Click on the obvious one, Upload attachment. Then you will see Filename: with an empty box, and to its right a button, Browse. Click the button, browse on your system to where the photo is located. Select it. The file name will appear in the box. Now you must click the button, Add the file. It will then be uploaded.
Keep in mind that the web board software imposes a maximum file size limit, and is set to resize by dimensions, any photo that exceeds that. This should not be a problem as it does not take huge-resolution images to depict an issue.
jaysto
ram: 4GB
Post by jaysto »
Thank you Ron
For the Upload file attachment informati0n. I shall give it a try when next needed
jaysto
Jaysto
Post by BrianCee »
Using system restore on a computer never changes any user files - only system files - so using system restore will never change an mpeg back to vob - you can if you wish do it manually - exactly as you renamed vob to mpg in reverse. but then you will only be back where you started.
You said originally that you had these VOB files - but are they just files or are they inside a Video_TS folder . I am wondering if that is why you are having a problem - when importing videos from DVD to videostudio one normally browses to a video_TS folder and videostudio sorts itself out - but are you just browsing straight to a vob file ?
