I cannot edit .EMF files generated from PowerPoint 2007. I always obtain a blank image after introducing any resolution values at the input field. The same occurs with .WMF format. I need to import vectorial graphics from .PPT files with a specific resolution, and I do not see any other way to do that.
I have PaintShop Photo Pro X3 v.13.2.1.20 with last available patches and updates installed.
Please any help or user experiencing the same problem?
Francisco
EMF files not rendered
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
Re: EMF files not rendered
First of all there are some features in EMF that PSP x2/x3 cant render, but try it open in Inkscape and remove gradients and texts. Save as - in Inkscape there are some options, try them all.
I played with Inkscape and wanted import vector drawing to PSP x2/x3 for further editing. It is posible, and it works well. But you can use in Inkscape only basic things like paths, solid colors and others. But I can draw in Inkscape more efectively than the same vector drawing in PSP. I do not played with it too much so I can not say which tools are fully compatible for vector drawings between Inkscape and PSP. Final words: try export/import in WMF, EMF, EPS and SVG formats,... Good luck.
AartsnScience
- motherboard: Dell Precision 390
- processor: Intel Core2
- ram: 4GB
- Video Card: NVIDIA Quadro FX 550
- Hard_Drive_Capacity: 600GB
I can't import EMF files into Corel Draw 4. I've never had a problem with previous CD versions. The program keeps freezing and then shutting itself down when I ask it to paste or import EMF and WMF files.
Specifically I am trying to import a graph from Graphpad prism 5. I've imported other graphs from GP5 with no problems. This one is a slightly larger graph with more data sets, when I copy and paste it does not import with all the vector information (missing bars on graph). So I tried pasting it as an enhanced metafile which then gave me a low resolution item with much of the labels and lines missing. Importing as a windows metafile crashed the program. I also tried exporting the file from Graphpad as an EMF file and then importing the file to Corel Draw which crashed the program. As a test I've tried to import some other EMF files and again CD4 crashes. I bought the program a little over a year ago. How do I fix this?
I don't want to export as a tif as it the vector information does not transmit properly, without the line resolution needed for publication.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Have you tried using PSP X4? If not, then you can download the trial of PSP X4 here.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Aartsnscience -- as you may have guessed by now, this web board does not cover CorelDraw and its associated programs. You would be better posting your query on coreldraw.com/forums/
I assume aslo that you are talking about CD X4, and not CD 4 as you have type. You might want to correct that on the CD forum.
deleted
