Is there a way to change the border size on a picture frame? I'd like to fade out a picture, so
I used the Antique Vignette frame, but I'd like to make the picture area larger. Is there an adjustment
that can be made for the fade out section?
Picture Frame Size PSP X3
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Picture Frame Size PSP X3
If you did not use the FRAME CURRENT LAYER option, chances are you should have the layer "PICTURE FRAME" layer on your layers palette.
You can resize and increase the picture area of the frame by resizing the "PICTURE FRAME" layer. You can use the PICK TOOL, then drag the frame to a size that will allow you a much larger picture area.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Thanks. That helps.
Carl
Carl
