Hi Trevor, Thank you for getting involved.
I am struggling here for another reason but still related to the same problem, which is the subject of this thread.
Let me explain fully so you can understand more: -
I captured my footage using Adobe Premiere CS5 - it was shot in Widescreen as has already been stated. I used 3 DV tapes throughout my shooting (my son's wedding) and therefore captured 3 clips. These three clips were then transfered to the timeline in Premiere where I edited them somewhat and in particular increased the sound in about 12 places, relative to to the overall sound level, simply because I forgot to "zoom" my camera's mic when I should have. I was extremely succesful in doing this because I have a lot of knowledge using Premiere for editing purposes. My 3 tapes cumulatively were about 35Gb's. I then "exported the timeline and used no compression and came out with a Microsoft DV .AVI file roughly the same size, but edited as I want it. I spent hours editing and therefore I require this exported file to be the starting point for Authoring.
I think the problem is this -
When filming with a SD camera on tape in widescreen means that the camera films in 4:3 and places the footage stretched vertical on tape, this is called anomorphic widescreen. Premiere will automaticly see your footage as widescreen, if not you can set that straight in the Interprete Footage in the Project Window. Some players outside Premiere do not see the widescreen 'flag' so one has to set the Pixel Aspect Ratio by hand.
Ok that is what Premiere says about all this.
Anyhow I played about with VideoStudio Pro X4 yesterday but I regret I do not believe it was the right upgrade to my MovieFactory 6 Plus software in that it doesn't seem to have the quick and easy methods to create "slideshows", menus and all. Please correct me if I have this wrong but I believe I should have upgraded to MovieFactory 7 as my friend has lent me his copy and this seems to be the what I want. I do not want to embark on another lengthy learning curve, learning all about the features of another NLE or Authoring package - my 35Gb .AVI file is where I want to start authoring now.
So having imported the file into MovieFactory 7 again I get it playing back in 4:3 but as hope there isn't a "Distort Option" to revert it to playback in 16:9.
So I am back to the same problem. In fact I have two problems: -
1. Getting the timeline to playback in 16:9.........
a. My Opening Screen after adding the >AVI file: -
However using the Multi-trim Video in Advanced Editing I can select the start and end of the clip by pressing F3 and F4, which brings the selection (ie; all of it in this case) to the bottom of the screen where it plays back perfectly as can be see here: -
But where do I go from here? When I press ok, I revert back to the first screen where it's still in 4:3 and exporting just a small part of the clip and then importing it back also results in 4:3 playback.
I am toally confused about how Corel Products are interpreting my footgage these days - I haven't experienced this before. As I have said my starting point is my existing 35 Gb .AVI file - this plays perfectly in Premiere, VLC Player and Windows Media Player. However importing it into one of Corel's Products seems hopeless, bar VideoStudio Pro X4, where you have to tweak the Distort Option. But this program doesn't seem to offer what I want.
Maybe I will have to export from VideoStudio's timeline then import the resul into MF 7 - would that do the trick anyone?
2. As I have already indicated, I want to create a disc which will take my edited footage without any deterioration in quality and add to it further small mvie clips and a few slideshows. MovieFactory does this seamlessly as I have done it before - VS doesn't, I do not think. I want to end up with a disc, probably larger than 8.5Gb but less than 25Gb so would like to know how to author to take advantage of the actual size afforded by BD 25's. This is the secondary peoblem though and not quite as important as my main problem above at this point in time.
Thank you in anticipation of some more help with this matter - I cannot believe that I am the first with this problem
roz
