I have an image that I want to save at 200 dpi. The image is a png file and is 550 by 550 in pixels. I currently have the image set a 1000.000 PPi -
Of course I own PSP X3 - and I probably should know this but anyway - ??????
DPi / PPi
Richard-psp
- motherboard: N Alvorix RS880 - UATX
- processor: AMD Phenom II x4 945 Quad Core 3 GH
- ram: 8GB DDR3
- Video Card: Radeon HD 5450
- sound_card: Intergrated ALC888S VD AUDIO
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: ACER 21 LCD H203H
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
Re: DPi / PPi
Go to Image > Resize. Remove the tick from beside "Resample using", and set your new resolution in the top section.
Later, if you view the image's properties, you'll probably see the resolution as 78.74 pixels per centimeter. This is exactly the same as 200 pixels per inch, but PNGs use metric units for their resolution.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
