Workaround for "Plugin can't read the requested format"
aldridgem
Post by aldridgem »
Hi All,
Am new to this forum, but thought I would post an intetesting observation regarding a .DDS plug-in I have been using in PhotoX3.
I get the error "Plugin can't read requested format" when trying to open a .DDS file, however other .DDS files open and are working on my PC. :cry:
I traced this issue down to where the image file is located. If it's buried in several subfolders it looks like PhotoX3 can not handle long paths for the filename. It looks like around 100 characters is the limit give or take.
The work-around is to either re-locate the file to a higher level folder e.g. trying placing the image file on your Desktop then open it or try shortening some of the folder names used in the path. :)
With that done, opening the .DDS file occurs without the error.
Since I only have this plug-in installed, this isue may crop up for other plug-ins I suspect.
Apologies if this issue is already known. I tried searching the forums prior to posting this but could not find anything.
Hope this helps... :wink:
Regards
Mark
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Workaround for "Plugin can't read the requested format"
Post by LeviFiction »
Interesting tid-bit there. Thank you for pointing it out.
I've only ever seen that error when I'm typing in the full path to the file in question and the full path is longer than 100 characters. If I actually navigate to the path, however, I have never seen this problem.
Since it does occur when you have a format supplied by a plugin selected in the format drop down it is a definite problem with plugins only. But so long as I'm actually navigating through the folders instead of typing in the location I'm usually good to go.
Madcowie
motherboard: Asus p4
processor: I7 Intel
ram: 16gb
Video Card: GTX 680
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: LG
Post by Madcowie »
aldridgem wrote:Hi All,
Am new to this forum, but thought I would post an interesting observation regarding a .DDS plug-in I have been using in PhotoX3.
I traced this issue down to where the image file is located. If it's buried in several sub folders it looks like PhotoX3 can not handle long paths for the file name. It looks like around 100 characters is the limit give or take.
Since I only have this plug-in installed, this issue may crop up for other plug-ins I suspect.
Hi, I actually registered here to try and PM you but no info. So will post here with a hope of an answer. After seeing your post you gave me hope that this might work.
So I moved the NormalMapFilter64.8bf file into a folder created here d:\ddsplugin
I then loaded Corel Photo Pro X3 and went to file\preferences\file locations and selected plugins from the menu on the side and assigned the directory I had created to d:\ddsplugin
Then closed and re-opened and it still doesn't work :(
Any help?
Stu
Regards
Mark
