Snow in FX?
daddog
Snow in FX?
Post by daddog »
In VS X4 I see the clouds, rain, lightning, but did not see an option for snow in FX. Anyone know how to do that or where I could download one? :)
After the search I had several hits, but most from years ago in older versions.
As always thanks in advance. :)
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
AussieTX
motherboard: Gigybyte 990FXA-UD3
processor: AMD FX8350
ram: 16 Gig
Video Card: Assus HD 7770 2GB GDDR5
sound_card: On Board Audio
Hard_Drive_Capacity: 2 T
Monitor/Display Make & Model: Asus 23" IPS + Acer 23" IPS
Re: Snow in FX?
Post by AussieTX »
Did you try using the Flash MotionF17 or MotionF19 as these are snow flakes.
You could place these in and Overlay track instead of an FX.
Cheers
Pat
Jack of all trades,
Master of none!
Re: Snow in FX?
If you play with the settings for the Rain filter you can get snow. You need to adjust the length and width, so that it is not linear. Then start working the other settings. The filter is keyframeable, so you will need to go to the last keyframe to adjust the parameters there.
daddog
Re: Snow in FX?
Post by daddog »
Thank you Pat.
I will try the rain filter since I don't know anything about Flash. :)
Thank you both. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Re: Snow in FX?
What Pat was pointing out that there are 2 samples found in the Flash Animation Library of VS. They are SWF files, you just drag-n-drop them onto an overlay track. They are 32 bit, meaning they have transparency. You find them by clicking on the Graphic icon (flower looking), the Color library opens. Press the drop-down menu, select Flash Animation. Locate MotionF17 and MotionF19, they're both SWF files, of animated snowflakes.
