X4 Audio BUG?
BUGS-R-US
motherboard: P7P55D-E Pro - Asus
processor: i7 860 - Hyper 212 CPU Cooler
ram: 16 Gigs
Video Card: 1 Gig Radeon HD 5770 ATI - latest driver
sound_card: VIA High Def Audio + Tascam US-144mkII
Hard_Drive_Capacity: 5 Terabyte
Monitor/Display Make & Model: Samsung 24" 1920x1200 X 2
X4 Audio BUG?
Post by BUGS-R-US »
Just upgraded from X3 to X4 - created first project and as soon as I started trimming the video, I noticed that when I scrubbed through the project, there was no sound! I then tried scrubbing each clip, and that worked, then I tried scrubbing the project again, still no sound - tried clip on timeline and now no sound there also.
Threw out the clip, deleted the project and started over - same thing happened - audio dropped out as soon as I started cutting down the clip on the timeline.
Took exact same clip (simple .avi file) into X3 and works fine. Cutting it and editing it to hearts content, sound works fine in X3. Started over again in X4 - audio drops out AGAIN!
ZERO sound issues in any other program I have been using. Audio works fine in all other applications, except X4.
Your thoughts?
Yes "enable audio on scrubbing" is on - the audio is disappearing entirely from the clip. No audio on any form of playback as soon as I edit the clip on the timeline.
I have been playing with various clips and it seems X4 only does this on certain clips - namely the ones I have converted from .FlV to AVI - BUT, X3 handles them ALL fine!
Sony HDR-FX1
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: X4 Audio BUG?
Post by skier-hughes »
I'm afraid there is no such thing as a simple .avi file, with well over 800 different types, could you tell us which yours is.
danish_zombie
motherboard: acpi x64-based pc
processor: amd athlon tm II Dual-Core M320
ram: 4gb
Video Card: amd m880g with a ati mobility radeon hd 4200
Hard_Drive_Capacity: 320gb
Monitor/Display Make & Model: generic pnp monitor
Re: X4 Audio BUG?
Post by danish_zombie »
Yeah i have the same problem to. but i just to busy to find the problem so i just split the sound from the video and save it, when i done with the video i add the sound back into it. but i would be nice if i did not have to do that all the time. no fun when i forget and have to start over. thank u for your post Bug-r- us.
BUGS-R-US
ram: 16 Gigs
Re: X4 Audio BUG?
Post by BUGS-R-US »
skier-hughes wrote:I'm afraid there is no such thing as a simple .avi file, with well over 800 different types, could you tell us which yours is.
Details I have, but which "type" by some kind of specific name, I have no clue:
Both .avi files were .flv files converted via Mobile Media Converter to .avi - both .avi files play just fine in X3 and X4 and in Media Player and VLC media player and in Windows Live Movie Maker, UNTIL I try to adjust them in X4 - then the audio ceases to work.
I have not had the time to play with .flv files converted via another conversion tool nor have I tried to import much of anything else with X4 as bugs tend to ruin the work flow pretty quickly.
First one I tried :
Frame Width: 720
Frame Height: 480
Data Rate: 28808kbps
Total Bitrate: 30344kbps
Frame Rate: 29 fps
Audio
Bit Rate: 1536 kbps
Channels: 2 (Stereo)
Audio Sample Rate: 48 khz
Second One I tried:
Frame Width: 1920
Frame Height: 1080
Data Rate: 700kbps
Total Bitrate: 828kbps
Frame Rate: 25 fps
Audio
Bit Rate: 128 kbps
Audio Sample Rate: 44 khz
thanks
Sony HDR-FX1
Re: X4 Audio BUG?
Please right click on the problem files *inside* Video Studio -- either in the timeline or in the library window, and then either make a screen grab and post the image here; or else manually copy ALL the properties here please. These will include exactly what type of AVI we are dealing with...
BUGS-R-US
ram: 16 Gigs
Re: X4 Audio BUG?
Post by BUGS-R-US »
Microsoft AVI Files
10,942 KB
25,000 Frames / sec
59.920 seconds
180.95 kbps
Video:
Compression: Mpeg4 Decoder DMO
Attributes: 24 bits, 1920 x 1080
Total Frames: 1,498 frames
Audio:
Compression: MPEG Layer-3
Attributes: 128 kBits, 44,100 Hz, Stereo
Total Samples: 2,643,840 samples
FYI - while X3 has been working fine for this type of file, I just now also got the same problem as X4, the audio ceased working as soon as I split the clip, deleted part of the clip and then tried to play the remaining project.
Sony HDR-FX1
Re: X4 Audio BUG?
Post by Black Lab »
Some types of MP3 audio files have been known to cause problems in VS. Try converting them to WAV files.
sowen
Re: X4 Audio BUG?
Post by sowen »
I'm having this exact same issue. I found others here with the same problem but no solution. It seems like all the solutions just blame you. I need this ASAP for a project. If I can't get this to work within the next hour, I'm going to have to try another video editor.
jtsu1
motherboard: GA-Z68A-D3H-B3
processor: i5-2500K
Video Card: mobo Z68
sound_card: mobo Z68
Hard_Drive_Capacity: 1.5TB
Monitor/Display Make & Model: Sceptre X9 19"
Re: X4 Audio BUG?
Post by jtsu1 »
@BlackLab is correct. VS X4 has problems with some versions of mpeg3. I had a similar issue with a video transcoded with handbrake utilizing the Lame audio encoder. I re-transcoded the video using the AAC encoder and the "no audio" issue was resolved. Below are the BAD and GOOD video properties in hopes it may be useful for others:
BAD
(audio codec: lame, Dolby Pro Logic II, Bitrate=160)
File format: MPEG-4 File
Video
Video type: H.264 Main Profile Video
Total frames: 5,630 frame(s)
Attributes: 24 bits, 720 x 478
Frame rate: 23.991 frames/sec
Data rate: 755 Kbps
Audio
Audio Type: MPEG Audio Layer 3
Total samples: 11,258,496 Samples
Attributes: 48000 Hz, 16 Bit. Stereo
Bit rate: 128 Kbps
GOOD
(audio codec: AAC, Dolby Pro Logic II, Bitrate=160)
Video
Data rate: 755 Kbps
Audio
Audio Type: MPEG AAC Audio
Total samples: 11,257,856 Samples
Bit rate: 160 Kbps
DimensionalKat
Re: X4 Audio BUG?
Post by DimensionalKat »
I am in the same predicament. It is not the sort of file, as I have tried many (and even the Samples from within the program). Please help, I need this soon for a project
Juddster
processor: AMD Phenon II X6 1090T Proc 3.2GHz
ram: 4GB
Video Card: NVidia GeForce 210
Hard_Drive_Capacity: 200GB
Monitor/Display Make & Model: ViewSonic VG930m-3
Re: X4 Audio BUG?
Post by Juddster »
I had this exact same problem, sound would play on the clip ok, but not on the project. It probably happened after upgrading from Windows 7 to Windows 10.
Initial testing shows that by ticking "Enable 5.1 Surround" from the settings menu drop down has fixed my problem as detailed here.
http://forum.corel.com/EN/viewtopic.php ... ct#p311321
I haven't created my project yet though, hope its fixed there also.
Chris
