WinDVD Pro 2010 Not Responding
Moderator: lata
dmann1987
motherboard: Maximus III Formula
processor: i7 860
ram: 4GB
Video Card: HD5870
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer G24
Post by dmann1987 »
Fresh install of Win 7 Home Premium x64. Got everything up and running. Installed the latest version of WinDVD. Popped a Blu-Ray in and nothing. The program stops responding as soon as the disc is popped in. I've tried different movies and disc images as well.
darrin1987
Re: WinDVD Pro 2010 Not Responding
Post by darrin1987 »
At least I have audio!
nepenthe
motherboard: Gigabyte GA-P55A-UD3P
processor: i-7 860
ram: 16 GB
Video Card: Gigabyte GeForce GTX 470 SOC
sound_card: onboard Realtec audio
Hard_Drive_Capacity: 600 GB
Monitor/Display Make & Model: NEC MultiSync EA192M
Post by nepenthe »
dmann1987 -
We need more information about your hardware. Are you certain you have a Blu-ray optical drive? Have you updated the optical drive firmware? Have you selected the correct optical drive region code? Is your optical drive recognized in Windows?
Check the Device Manager to confirm that the optical drive is working properly. Update the device driver if there is an available update. If Windows isn't recognizing the device, you may need to delete upper and lower filters:
http://bit.ly/fGUHvP
Please post back in this thread with the results of your efforts.
nepenthe
dmann1987
processor: i7 860
ram: 4GB
Video Card: HD5870
Post by dmann1987 »
This is my drive. http://www.asus.com/Optical_Storage/Int ... /BC06B1ST/
There are no firmware updates for it.
The region code is correct.
The drive is recognized in Windows.
I just discovered that WinDVD is not playing DVDs either. Trying to play one results in blank video with choppy and distorted audio. WMP plays the DVDs. Everything worked a couple weeks ago.
nepenthe
processor: i-7 860
ram: 16 GB
Post by nepenthe »
dmann1987 -
If everything was working fine a couple of weeks ago, I suspect a corrupted WinDVD driver. The solution is a thorough uninstall and clean reinstallation.
I suggest using the free Revo Uninstaller (advanced mode):
http://www.revouninstaller.com/
Just to be safe, after you have run Revo Uninstaller in advanced mode, perform a Registry cleaning with the free CCleaner:
http://www.piriform.com/ccleaner
Now reboot and reinstall WinDVD. Check within the application for any updates, and try to play a DVD or Blu-ray.
nepenthe
natakuc4
motherboard: 0Y2MRG Dell XPS8300
processor: i7-2600 3.4GHz
ram: 12GB
Video Card: ATI Radeon HD5770 1.0GB
sound_card: Creative Soundblaster X-Fi Xtreme Audio
Monitor/Display Make & Model: 2×Dell E176FP
Post by natakuc4 »
Hey
Seems similar to my issue, do you have an ATI graphics card? If so disable the ATI or AMD HD Audio Device in the device manager.
Then try launching WinDVD.
