Unable to add copyright info in Moviefactory 6
colinbarratt
Post by colinbarratt »
Hi - Hope someone can help with this. I want to add 'copyright' text to a clip I wish to upload to the Internet.
I used to use Ulead DVD Moviefactory 4 and could do it easily with that. However, using Ulead DVD Moviefactory 6, the option is no longer there to alter the duration that the added title will remain on screen.
When I go to Edit Room and put the Title Text in - it disappears after a few seconds (as you'd expect a title to do)... the 'clocl' which appears on the left side in uneditable.
Please - if you know how to do this in ULead 6 - let me know? Thank you!
Colin
Re: Unable to add copyright info in Moviefactory 6
Post by BrianCee »
While in the edit room - switch to timeline mode ( small icon at top left corner of the storyboard/timeline - looks like two frames of a film strip) - now click directly on the title block in the title track - and the clock will become available to you - or you can drag the yellow handles at each end of the title block to set a length.
colinbarratt
Brilliant Brian!!! Thank you very much for your prompt and knowledgable answer. Works exactly as I had hoped. I owe you a pint next time you're in Newcastle!!!
Colin
