No sound creating DVD
nblecher
- motherboard: asust p4b266la
- processor: intel pentium 4
- ram: 2 gb
- Video Card: nvidia riva
- sound_card: mpu-401
- Hard_Drive_Capacity: 1000 gb
- Monitor/Display Make & Model: hp 1702
I have a short project which I am trying to burn on to a DVD. When I play the DVD after I have successfully burned the project, I get video but no sound. I have tried both normalize audio checked and unchecked with the same results. I am using DVD-video as the recording format. I am running VS Pro x4. Where does the problem lie and how can I correct it?
Re: No sound creating DVD
Unfortunately, we simply do not have enough information to be able to make even a reasonable guess at a solution.
We have no idea what your original video format is, and what kind of camcorder or other device was used to film it; nor do we know anything about your workflow -- for instance, did you insert your video and edit it, then produce a new DVD-comaptible mpeg-2 (Share > Create Video File > DVD); or instead did you jump straight into the burning module (Share > Create Disc)?
Please have a look at this sticky post at the top of this forum -- it is called, indicatively, PLEASE READ THIS BEFORE POSTING http://forum.corel.com/EN/viewtopic.php?p=41454#p41454 Then get back to us with the information requested and hopefully someone will be able to help.
Usually, this means that Video Sudio is having trouble with the file you're feeding-in. (It's usually a from problem, rather than a to problem.)
What format is your original audio/video (specifically the audio properties)?
What are your project properties?
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Along with your video/project properties it may help if we knew which country you live in (not all audio formats work in all countries) - in fact why not fill in the "Location" field in your profile so that your location appears at the right like mine.
