Plugins not useable
Sheila
processor: AMD Athlon II X2 220 Processor 2.80 GHz
ram: 2.00 GB
Video Card: GeForce 6150SE nForce 430
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Hanns.G HF25
Plugins not useable
Post by Sheila »
I have made a separate folder for my plugins and made my folder preferences. When I select Effects and chose a plugin it shows up but I get the following message: Unable to load requested plug-in filter. The plug-in may not be installed properly or may be missing files.
Any help would be greatly appreciated.
Sheila
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Plugins not useable
Post by LeviFiction »
Well, my first suggestion would be that the plugin is missing a file or something. Double-check the installation.
Some important questions are which version of PSP are you using? I'm assuming you're saying every plugin is like this so can you give us an example of some plugins that are acting like this? Do any of them rely on an external .dll?
PSPX3, as of patch #3, made some changes to the plugin system which has caused problems with some plugins but we can't always blame this patch for all plugin errors. Especially if you haven't installed patch #3, or you aren't using PSPX3.
Some ideas would be running PSP as administrator (Right-click the icon and select Run As Administrator). I've found this was necessary when running a plugin that wants access to an external file.
Others might have better suggestions but if these don't help then answering the questions I asked and anything else you feel is important and maybe we can get some better suggestions.
Sheila
ram: 2.00 GB
Post by Sheila »
I'm running X3 and have installed all the available patches. This is on all filters, Andrews, Almathera, etc.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
Download http://www.corel.com/6763/psp_downloads ... vcrt10.zip. Extract MSVCRT10.DLL from the file you downloaded and copy it to your C:\Windows\SysWow64\ folder.
Tim Morrison
C-Tech Volunteer
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Post by pdxrjt »
What if you get a similar problem on Windows XP (using X3 with all available updates?) Where do you put the file?
Adverts for Corel products when you close PSP don't bother me.
Sheila
ram: 2.00 GB
Post by Sheila »
Thank you for the dll, I added it to my syswow folder but that did not solve the problem. Are there more dll's that should go in the folder by any chance?
Tim Morrison
Moderator
processor: 3.16 GHz
ram: 2GB
pdxrjt wrote:What if you get a similar problem on Windows XP (using X3 with all available updates?) Where do you put the file?
In XP (the standard 32 bit version anyway), it should go in C:\WINDOWS\system32.
In theory the DLL should go in a folder that is in the system's path, or in the folder of the program that calls the DLL. Open a command prompt by entering "cmd" in the Start Menu's Run box and press enter. Then type "set" (without the quote marks) and press enter. You'll see a list of system variables. One line will start with "Path=" and contain several lines of folder addresses. (You may have to scroll up to find it).
There won't be any problem, apart from a tiny bit of wasted space, if you place copies of MSCVRT10.DLL in more than one place.
Tim Morrison
C-Tech Volunteer
Tim Morrison
Moderator
processor: 3.16 GHz
ram: 2GB
Sheila wrote:Thank you for the dll, I added it to my syswow folder but that did not solve the problem. Are there more dll's that should go in the folder by any chance?
Some older plugins need a copyright Adobe file called "plugin.dll". Although it's not legal to install it unless you own one of the Adobe programs that ship with it, you'll find it to download without much trouble.
You might also find that some plugins won't work under 64 bit versions of Windows. You will need to see if the plugin author has a newer version, you may need to disable DEP, or you may need to fix the plugins using FM Patcher - http://www.filtermeister.com/fmpatcher/index.htm.
You will find more info at the The Plugin Site, particularly at http://www.thepluginsite.com/knowhow/tu ... uction.htm, and at their forums - http://www.thepluginsite.com/forum/index.php.
Tim Morrison
C-Tech Volunteer
pdxrjt
ram: 32 GB
Post by pdxrjt »
Sheila
ram: 2.00 GB
Post by Sheila »
The got the plugins to show up by putting the dll in both the system and syswow folders. Now the whole program shuts down when I try to use one.
Any ideas? Help greatly appreciated.
Sheila
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Did you try disabling DEP for PSP X3? I had to do that to get my DC plug-ins to work. However, I did have many other plug-ins that did work with DEP enabled so I guess it depends on the plug-in.
Sheila
ram: 2.00 GB
Post by Sheila »
I don't know how to disable the dep. Instructions faithfully followed.
Instructions for disabling D.E.P. for WinXP and Vista, just add PSPP instead of VS.
http://forum.corel.com/EN/viewtopic.php ... 08#p164308
Sheila
ram: 2.00 GB
Post by Sheila »
Thanks for the link, it didn't work though.
Sheila
Kathy_9
Post by Kathy_9 »
Rats!! That has to be frustrating. Maybe try removing and re-installing one of your plug-ins just to see if that will get it to work?
