How do you use the free trmplates?
alanball
motherboard: Gigabyte Technology B450M H
processor: AMD Ryzen 5 3600 6-Core
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 SUPER
Hard_Drive_Capacity: 2TB+480SSD
Monitor/Display Make & Model: ASUS VN247
Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Post by alanball »
Has anyone seen a tutorial on how to use the free templates?
thanks
Alan Ball
Re: How do you use the free trmplates?
Post by Trevor Andrew »
Hi Alan
Most are associated with the Instant Projects option.
When you install the template files are saved to your hard drive.
here for XP :-
C:\Documents and Settings\User Name\My Documents\Corel VideoStudio Pro
The folders contain a short Project VSP.
It also contains a UserTemplateStyle.vpt file.
This can be imported to the Instant Project library.
alanball
ram: 16 GB
Post by alanball »
Hi trevor,
so they are not intended to be imported into a normal editing session as well as instant projects then?
thanks
Alan Ball
Yes they are intended to be used in a normal editing session. You get them to the editor through the Instant Project wizard. Once they're installed, then go to Instant Projects, press the Import Project icon. Then navigate to one of the installed templates. The Instant Project wizard will only use/import the VPT file. Once the project is imported to the Wizard, then you can select it, to be inserted to the Beginning or End of your project, in the Editor.
The images are placeholders, and can easily be replaced by images of your liking, simply by dragging your image over the top of the placeholder image, then while holding the Control key down, drop your image ontop, which replaces the placeholder. All the effects are automatically added to your image...
alanball
ram: 16 GB
Post by alanball »
Thanks Ron & Trevor
I think I have the idea now and will give them a try.
Alan Ball
