Hi I am new to using paintshop pro x3 This error keeps occurring when trying to use the Local Tone Mapping it has happend on another option but cant remember what one but will keep trying to find what else gives the error.
I did search the forum for an answer and 2 threads came up but nothing with a solution so I did a search and Microsoft if my understanding is right its a programming error within the application in this case Paintshop Pro X3, Here is the link to Microsoft where I read the posts. http://support.microsoft.com/kb/125749
If someone has managed to get around this I would love to know, Oh Also I have updated Paintshop Pro X3 but the error still comes up.
Thanks in Advance
Steve.
Runtime Error R6025
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Re: Runtime Error R6025
Make sure that you install all of the patches, and I'd suggest that you install all of them in order too. There was a common problem with the program when it first came out that the first patch fixed. It sounded much like this, if not just like this. The problem was when you had the option to view the adjustment on the image active it crashed the program. If you were lucky enough to uncheck that option then the program ran pretty well.
Don't assume that patch #4 includes the previous 3, although I don't think we've heard anything officially on that yet.
Regards, Dan
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
You don't need to install patch 1... it's included in patch 2. You need to install patches 2, 3 and 4 separately and in order.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
Thanks both for your reply's It is for the ultimate version purchased a few days ago, I did all the updates that it requested through the update within Painshop Pro X3 the version I am running is 13.2.1.20 and it says no updates availible when I press it now so I guess it got them all the ones it needed.
Here is the system info that you can get from the about screen just incase it helps in anyway.
PaintShop Photo Pro Build Information:
Build Date 07 December 2010 @ 17:17:22
Build Mode Release (D000000)
Hardware Configuration:
Processors 4
Processor Type Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
MMX Support Yes
Memory / Drive Status:
Memory Load Index 30 pcnt.
Total Physical Memory 3.74 GB
Available Physical Memory 2.60 GB
Total Paging Memory 4.00 GB
Available Paging Memory 4.00 GB
Total Managed Memory 5 MB
Total Handles: 49
Temp Drive Free Space 409.01 GB
Video Driver Information:
Bits Per Pixel 32
Number of Colors 16777216
DIB Output 24 BPP
Palette Size Non-Paletted
Resolution 1920 x 1080
Operating System Information:
Operating System Windows 7 Service Pack 1
Plug-in Information
Filter Plug-ins Loaded: 24
Import Plug-ins Loaded: 0
Export Plug-ins Loaded: 0
Format Plug-ins Loaded: 0
DLL Name Version Load State
CmdArtistic 13.00 None
CmdBase1 13.00 Partial
CmdBase2 13.00 None
CmdBevels 13.00 None
CmdClipboard 13.00 None
CmdColor 13.00 None
CmdEmail 13.00 None
CmdExternal 13.00 None
CmdFile 13.00 None
CmdGeometry 13.00 None
CmdJGL 13.00 None
CmdLayers 13.00 None
CmdLighting 13.00 None
CmdNonGraphic 13.00 Partial
CmdOrganizer 13.00 None
CmdPhoto 13.00 None
CmdPhotoSharing 13.00 None
CmdPrint 13.00 None
CmdPyScript 13.00 None
CmdSelections 13.00 None
CmdSlideshow 13.00 None
CmdStandard 13.00 None
CmdTexture 13.00 None
CmdVector 13.00 None
CmdWeb 13.00 None
ToolArt 13.00 Partial
ToolObject 13.00 None
ToolPaint 13.00 None
ToolSelect 13.00 None
ToolStandard 13.00 None
ToolText 13.00 None
ToolWarp 13.00 None
WinTab Tablet Status
Driver Version: 1.0
Supports pressure: Yes
Processors 4
MMX Support Yes
Total Handles: 49
Bits Per Pixel 32
DIB Output 24 BPP
Plug-in Information
CmdBase2 13.00 None
CmdColor 13.00 None
CmdEmail 13.00 None
CmdFile 13.00 None
CmdJGL 13.00 None
CmdPhoto 13.00 None
CmdPrint 13.00 None
CmdWeb 13.00 None
ToolText 13.00 None
ToolWarp 13.00 None
Driver Version: 1.0
Simone Corel UK
- Alludo
@Sa1 UK
This proble doesn't appear generally and is no programming error (as the Microsoft wepage suggests)
Check your graphic card driver and download the latest version directly from the manufacturer's website or contact the Corel support.
