Animator crash?
godawfulcharade
Animator crash?
I have been using Ulead for a while now
Today I log on and try to open it and every time I get error message reading: Ulead GIF Animator has encountered a problem and needs to close. We are sorry for the invonverience.
I've clicked 'send error report' but is there anything I can do to fix this? Anyone know what the problem could be?
Liza
keenart
When ever you get the dreaded message, “A program has encountered a problem and has to close.” Usually your installation of that program has become damaged. A corrupt file, registry key, or something related to the programs function is now no longer working.
In this case you have few options, one is to Repair the program and hope it works, and the second is to uninstall the program and reinstall in hopes it will work as if new.
In the Control Panel, select Add and Remove Programs, in the Currently Installed Programs List, select PhotoImpact or Gif Animator. Two grayed buttons should appear, one named Change, and the other named Remove. To repair your program select Change, and do a Repair. To Remove the Program completely from the system, choose Remove.
If after Repairing your installed program and it still does not work then you will have to try to Remove the program PI or GA from your system. After doing so, before reinstalling the program, find the Two Folders named Ulead Systems, delete them and all of the contents, then empty the Recycle Bin, reboot your computer, reinstall your software.
If everything works you are in good shape, if not you have additional problems to be diagnosed and repaired.
godawfulcharade
Heres the thing, I bought it online so I don't have any discs for it.
I tried to repair, but it asks me for to 'insert disc 2'... and I have no disk 2. I can't get any further than that because of this.
I printed screeen do you can see
Also due to not having any discs I don't know if I can uninstall and re-install...
Pleae help me someone
I'm really annoyed. This program was really expensive for me. I'll be so sad if I can't get it to work again.
keenart
If would appear from the dialog box the Install Wizard is trying to access the Setup.ini file from your download. This is the file that tells the Downloaded file how to install the program to your system. The problem is whether you still have the downloaded File or it has deleted itself. Normally if you do a Save to Disc the file will remain in tact, but if you do a Smart download which installs the file after download it usually deletes some of the file contents and sometimes can not be reinstalled again.
If you did do a Save to Disk, and then opened and install the program later, the Ulead Download file should still be in the Folder you downloaded it to. It appears the downloaded file was installed in the C:\documents and settings\your name\local settings\temp\pft6c~tmp folder, I can’t read the rest. If so you can click on the Ulead Setup.exe file or the downloaded Temp file and it should try to install, you want to stop it from installing as this is just a measure to see if it still exists. If it tries to install then you should be able to uninstall the present working program and then reinstall from the downloaded file. That is if the File is in tact and not damaged.
If you are concerned about losing everything, then don’t do anything until you contact Ulead for a new download, or ask for a disc. You can go here:
Q: How can I re-download my product?
A: If you have purchased a downloadable (ESD) version of Ulead software from the Ulead Mall, please contact the the Customer Service Center provided by our E-Commerce solution provider, Element 5, for information about re-downloading our software. http://www.element5.com
I would suggest once you re-download your product you put a copy on CD before you try to install.
meupc
hey keenart, there isn´t anything wrong with installation, but looking at the instalation dates, I think that Uleag Gif Animator has not been updated since year 2002. Many files are from 1999 ???? and the main program date is from 22-jan-2002??????? How can u explain?
Maybe you need to update program, as we have now windows XP+Sp2, and maybe program not compatible with SP2.
keenart
Meupc
Since Service Pack 1 Microsoft has had to make major Security changes to its OS, the list is staggering. Encoding files for security purposes, creating scanners for Malware and it goes on and on. Should you do a search at Microsoft you will find many KB docs that list thousands of programs that will now NOT work with Win XP SP1 and especially SP2. Which is not the fault of the programs, that are out there now, but Microsoft for changing things in mid-stream. They are already downloading the beginning patches for SP3.
Many companies and their programs will have to weather the storm and try to keep up. That presents a serious financial stain on small companies, but not the Giant Microsoft, they don’t care and are not worried about any one but themselves. Read the KB’s they state they will kill any errant application at the expense of saving their OS (should read ***). They want to look good, because they are tired of getting bad press for being a @%# company!!!
It will continue to get worse, especially when Microsoft goes to the 64 bit OS. If you remember the debacle we had to put up with during the change from 16 bit and 32 bit you would understand what is happening to the Industry right now. The 32 bit and 64 bit transition will be just as difficult, for companies, and US as well.
Old file dates are not indicative of bad programming or failed applications. Many programs still use DLL’s that are from 1998 and upwards in date and work fine. Since, I used to be a programmer, I speak from experience. I still have an old DOS utility I wrote 20 years ago that installs and works fine, on any Microsoft OS, except XP. The fault is not mine because I have not updated it, it is Microsoft’s because they have changed the programming language that NOW makes my Utility non-functional. Which means, if I want my app to work, I have to rewrite the application to suite XP requirements. That is how much Microsoft has control over the rest of us, wake up!
Until Microsoft gets things straighten out many companies programs will have difficulty in one form or another. Even if Ulead rewrites the program from ground up and puts out a new version that is no guarantee it will not have troubles under the present Microsoft environment. That you can mostly blame of Hackers!!
meupc
emilk
I have followed with interest the discussing about GA crash problems, as I recently purchase a full version of Photimpact, despite the fact that I was only interested in the GA. As for many users, GA also doesn't work on both my home computers. They are both Dell's less than 6 month old, with all current Microsoft updates. I tried the uninstall solution, including the deletion of the directories, but still I'm unable to use GA. Obviously there is something wrong with the program. It starts loading GA, but crashes on the part where it tries to load the video drivers (??). I think Ulead should seriously looking into this problem, which obviously exists on their side. It's too easy to blame Microsoft for it, even they are responsible for most of the misery we encounter every day with their programs.
Goat_187
keenart
GA Animator comes in its own stand-alone software package with additional extras, which means you could have saved yourself some cash instead of buying PI.
http://www.ulead.com/ga/runme.htm
I would seem most people miss the point about Microsoft in relation to other software companies. They seem to get the feeling I am bashing MS, wrong, trying to point out the major reason companies are having difficulties and why their software may have problems even under the best of conditions and even with the newest rewrites.
Granted GA is an older program, but why is it Ulead’s fault that it doesn’t work with your Video Driver, when the video driver was written by another company. Yes, if Ulead wants to stay current it will have to rewrite the code and make your Video Driver compatible with GA.
Microsoft is in a continual state of change, constantly rewriting code to meet the onslot of Security Issues, and Third Party program compatibility. In an attempt to accomplish this they change code that was used by software companies that made the Third Party software work. Therefore GA now may not work for a few individuals, not because their software is bad, but because Microsoft or a Third Party changed code that causes Ulead’s software to malfunction? It can’t be any simpler than that!
I have personally never had any trouble with GA, and have used the software since PI 3, and currently I have 5 computers, all different makes, models, and OS, and in the past have had more than 2 dozens other types of computers. PI 10, brand new, on the other hand, gives me fits, ever since Win XP it is having trouble. PI 10 does not have trouble with my ME, it even works fine on win 95.
Human nature, blame someone for their troubles, never really understanding why. How many have gone to the Gallows innocent!!
meupc
U are a genius, the video filters (files dated from year 2001) are the problems. I still think that Ulead have to Update their software.Goat_187 wrote:Solution or Workaround:
Delete or rename uvavi.vio file in the "<Program Install Path>\VIO" folder.
However, features related to AVI file would be lost.
Running GA without deleting folder VIO gives this:
Maybe the problem are the files from 2001 below:
