Bring x4 file back into x3
garywp
- Video Card: nvidia
- Hard_Drive_Capacity: 1tb
- Monitor/Display Make & Model: dell24
Is there any way of importing vsp x4 files back into x3
Re: Bring x4 file back into x3
If you are talking about X4 project files .vsp, the only way is to Save As and select as Format X3. Otherwise, X3 can never read X4 files. Versions of VS are backwards compatible, but not forward...
garywp
My problem is that I downloaded and purchased x4 - only to have it quit on me. I've spent weeks trying to reinstall it with no success. The problem is that I started a project in x4 before it quit on me. I have gone through all the hoops that have been mentioned on this board and others. I cannot reinstall x4 -period. I thought that it might be something with Windows, but I've reinstalled x3 without problem.
I have decided to try Power Director as well.
Hi Gary
You need X4 to open the VSP, then you can save as a back issue.
But if you cannot install X4 then you can e-mail me the VSP
I will save it for X3 compliant and send it back.
Yes i will get a Re-Link request as i dont have your files, but i can ignore that.
Should work.
View my quick guide for e-mail address
Should work.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello garywp,
I'd like to help you with your VS X4 issue. First uninstall the program manually using the VSX4 CleanUp tool or following the steps on how to remove it manually.
You can download the VSX4 CleanUp tool here ftp://ULQPBRY2:2ECSVEGZ@Private.ulead.c ... leanup.zip, just run the removal tool and follow the steps that you will see on the screen to remove program from your computer or you can also follow the steps below to manually remove VS X4.
1.) Go to Windows Directory; delete the following folders/directories:
a. C:\Program Files\Corel\Corel VideoStudio Pro X4
i. For Windows XP -->
1. C:\Documents and Settings\[YOUR USERNAME]\application data\Ulead Systems\Corel VideoStudio Pro\14.0
ii. For Windows Vista/7 -->
1. C:\Users\[YOUR USERNAME]\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro\14.0
2.) Go to Start >> Run and then type: regedit
3.) Hit "OK" to launch Regedit window.
4.) Go to "My Computer\HKEY_CURRENT_USER\Software\Ulead Systems\Corel VideoStudio Pro"; delete the folder "14.0"
5.) Go to ""My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Corel VideoStudio Pro""; delete the folder ""14.0""
6.) Go to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Installer > UserData > S-1-5-18 > Products;
7.) Locate and delete the following keys that corresponds to Ulead VideoStudio Pro X4 (14.0.0.342):
a. 13C209AAD94B8064CBFC5291BE7727D2
b.1EBCE48B5DE668E44BBAFD643D2414F1
c. 236E09933C2452A4DAFF11103E6DDD74
d. 42CAF78BD379F4A4FA4C55F59BB523BD
e. 5FCB9D8DF5F0F3D44872467B36F239EB
f. 8048774C8623EC54EA5177D271931A1F
g. AEE7106C15E9921448ABFE9A25E0968D
h. B9E7C4CC62B4D8D4086704FC07A8F94A
i. BEB5210B1376AF3488AD6BD4B73DDAD2
j. CF79886DD8E7948418A927B6429817C3
k. ED58F70D1F224BF43B1D04F22DC28407
8.) Go to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Uninstall;
9.) Locate and delete the following keys enclosed in curly brackets that corresponds to Ulead VideoStudio Pro X4 (14.0.0.342):
a. {AA902C31-B49D-4608-BCCF-2519EB77722D}
b. {3990E632-42C3-4A25-ADFF-1101E3D6DD47}
c. {AA902C31-B49D-4608-BCCF-2519EB77722D}
d. {B0125BEB-6731-43FA-88DA-B64D7BD3AD2D}
e. {B84ECBE1-6ED5-4E86-B4AB-DF46D342411F}
f. {B87FAC24-973D-4A4F-AFC4-555FB95B32DB}
g. {C4778408-3268-45CE-AE15-772D1739A1F1}
h. {C6017EEA-9E51-4129-84BA-EFA9520E69D8}
i. {CC4C7E9B-4B26-4D8D-8076-40CF708A9FA4}
j. {D07F85DE-22F1-4FB4-B3D1-402FD22C4870}
k. {D68897FC-7E8D-4849-819A-726B2489713C}
l. {D8D9BCF5-0F5F-4D3F-8427-64B7632F93BE}
10.) Close the Regedit.
11.) Clean up temporary files and Recycle Bin by launching the Disk Cleanup from Start menu >> Programs >> Accessories >> System Tools >> Disk Cleanup.
12.) Restart your computer.
13.) Re-install VideoStudio Pro X4.
After removing the program reinstall by redownloading the program from the order email or corel account or using the disc installer.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
garywp
Thank you Abiel for your help. I followed your instructions to the letter. I used the cleanup and the manual removal of the vsx4. The install did start up, but got up to the 28% level before a message came up. I tried it about 6 times, all the same result.
Gary,
I've just experienced a similar error, however it had to do with SmartSound QT5. While attempting to get some older sound files into Sonic Fire Pro, I managed to mess up the install of SS QT5. So anyway I received a very similar error. You need to look at the file it is asking for, the *.msi file. You should also see a Browse button, which can be used to go look for that file. It should be located under the Setup folder.
carobles55
Hi, sorry to be so ignorant, but, how do i ask a question? the faq said to click on the relevant button, but i cannot find that.
thank you.
thank you.
garywp
I FINALLY GOT IT! It took me about a dozen tries, each one made a little further progress on the status bar, until it finally installed - so I'm happy again. I followed the step-by-step instructions as posted above. I'm not sure I understand why, but the vs I downloaded stated 15......., but the one actually loading and that I'm working with is 14.0... I'm not sure what that is all about.
Thanks for everyone's suggestions.
