"Load from stream error"
KOBRA76
motherboard: Gigabyte
processor: 3.07 gigahertz Intel Pentium Dual-Core
ram: 2 GB DDR3
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 500GB
Post by KOBRA76 »
when i upload klips to the libary i recive this massage "load from stream error"
what is thate?and what i must to do to not recive this massage?
thanks
Canon 550D,18-55 & 50mm Lenses
My You Tube Channel
http://www.youtube.com/user/HDMAN2012?feature=mhee
Re: "Load from stream error"
What version are you using?
Apparently some data (*.dat) files have been corrupted. Should not be that difficult to fix. Go to C:\Documents and Settings\YourUserName\Application Data\Ulead Sytems\Corel VideoStudio Pro. If your having this problem with VS X3, open the 13.0 folder, locate and delete the VS_Video.dat file. You could also just delete the whole 13.0 folder. Once you restart VS, that folder will be rebuilt.
If you have any custom libraries you will lose them, so you may want to first back-up these files:
  • VS_Video.dat
  • VS_Title.dat
  • VS_Project.dat
  • VS_Image.dat
  • VS_Flash.dat
  • VS_Decoration.dat
godive
motherboard: Quanta 30D1 85.26
processor: 2.10 gigahertz AMD Turion 64 X2
ram: 4gb
Video Card: NVIDIA nForce Networking Controller
sound_card: HDAUDIO Soft Data Fax Modem with SmartCP
Monitor/Display Make & Model: Hannstree and HP laptop display
Post by godive »
I too cannot open VS pro X3 because of this error. Running windows 7 - 4 gig memory, I was trying to delete thumbnails from the base video library group and VS hung for over 10 minutes. I closed the program (hard close via program manager) now when I open it i get Load from stream error" on each of the thumbnails I tried to delete then the program hangs. I tried your suggestion above and found the file under the folder /ulead.dat. That did not work. I then deleted the folder 13.0 under documents that you listed above and again that did not work. I am at my wits end.
Bill
vdcauter
motherboard: Asus Sabertooyh 55i
processor: Intel Core i5 760
ram: 16 GB
Video Card: Nvidia GeForce GT 240
sound_card: C-Media CMI8738 C3DX
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: Samsung SyncMaster 23" 1920 x 1080 px
Post by vdcauter »
Deleting the six mentionned *.dat files did not work for me in VS 14 PRO. Instead, I deleted ALL the contents of the "14" folder without deleting the folder itself (You may, of course first keep a safety copy at another location in case you are afraid something could go wrong). After reopening Video Studio it took some more time for the program to open as it reconstructed from scratch everything I had deleted. But after that, no error anymore. The only thing you are losing are your self made directories as VideoStudio now only shows its default directories.
Sorry for my poor english but I am using a french version of VS 14.
Arcorias
motherboard: Fujitsu
processor: iCore 3
ram: 4 GB
Video Card: ATI 550v
sound_card: Realtek
Hard_Drive_Capacity: 320 GB
Monitor/Display Make & Model: Fujitsu
Post by Arcorias »
I just had this problem with VS X9. This helped:
Close VideoStudio, go to Start Menu and type this on the search field (on Windows Vista/7) or Run command (on Windows XP): %appdata%
Hit the enter key to open the Application folder (on Windows XP) or the "Roaming" folder (on Windows Vista/7). Then go to the "Ulead Systems" folder > "Corel VideoStudio Pro" folder (there could be two of these folders, one with "(x64)" at the end for 64 Bit Systems), and rename the "19.0" folder (e. g. to "19.0-backup").
Then restart VS. It will rebuild the folder. You might have to start VS again after this.
dangelic0
motherboard: Dell XPS 8920
processor: Core i7-7700 4.2 GHx
ram: 32GB
Video Card: NVIDIA GeForce GTX 1060 6GB
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: LG Ultra HD
Corel programs: PSP. VSP
Post by dangelic0 »
Thank you! Just found your post and it helped me a lot!
Dean
Meedily
Post by Meedily »
THIS is why old topics should never be deleted!!
I know it's over 5 years old, but I just had this error, and through following the instructions of going to search, typing %appdata% yada yada yada, just saved me from having to redo 3 weeks of work!!
Thank you!!
