I have created a project, click on Share, creat DVD. Then I added Chapters, named the chapters. Burn the DVD. When I went to play the DVD I could not access the sub - Chapters. The main menu would come up only, and then go right into playing the video.
What am i doing wrong. I have made two other DVD with out any problems. I have tried re-installing the program, still does not work right.
VSX4 DVD with Chapter problem
bjsolko
- motherboard: acpi x64
- processor: intel core 2 CPU
- ram: 2GB
- Video Card: NVIDIA GEForce 7500LE
- sound_card: conexant falcon 11 ntsc
- Hard_Drive_Capacity: 3 T
- Monitor/Display Make & Model: HP w22
Re: VSX4 DVD with Chapter problem
What type of menu did you use, SmartScene, Thumbnail, Text? Generally for example using Thumbnail menus, your Main menu thumbnail image, will take you to a Chapter menu, unless you select the arrow, which is the Play-all button. If you have more than one Title (video clips), you may have more than one Thumbnail on your main menu. If the clips have chapters, and you built a Chapter menu, you should next go to that Chapter menu. If it does not contain chapters, then it will play that clip.
How did you set up the navigation for your DVD? Clicking on the Project settings, gear icon, will open a dialog window. At the bottom of that dialog, will be a navigation section. You can set it to play all before going to a menu, or to play a title (not a chapter) then return to a menu.
bjsolko
- ram: 2GB
I used Thumbnail. I have 13 chapters, but only one image is one the main menu. How do I get the other images appear in the main menu?
