Field Order Question
gordon_fan_24
Post by gordon_fan_24 »
Ok what field order should I use if I have used both analog and DV sources in the video. Upper or Lower?
MikeGunter
Re: Field Order Question
Post by MikeGunter »
gordon_fan_24 wrote:Ok what field order should I use if I have used both analog and DV sources in the video. Upper or Lower?
DV is usually (always in the US) lower. Analog can be either, depending upon the capture device, CODEC, and such.
I'd likely try to capture analog as lower and use lower for the project.
Mike
Fuego669
Post by Fuego669 »
I suspect that the right answer would be to determine the field order of all of your source material and if it is mixed, de-interlace it so you can then re-interlace with the correct field order. Here is an interesting starter link http://nickyguides.digital-digest.com/i ... e-test.htm with doom9 providing more methods for processing further.
Other than trial and error, I am not sure there is a reliable way to tell what the field order is. If your source material comes from a DV camcorder, or if you're not sure, try "lower" first as advised above. If you find that your video flickers on playback it is probable that you have selected the wrong order.
Make short test clips of each of all of your source material and play them on your target.
