Converting 2D to 3D in VS X4
lassegus
- motherboard: Z68A-GD55 MS-7681 4.0
- processor: Intel Core i7-2600 3.4 GHz
- ram: 8172 MB
- Video Card: NVIDIA Quadro FX 380
- Hard_Drive_Capacity: 1410 GB
- Monitor/Display Make & Model: ACER X223W
Re: Converting 2D to 3D in VS X4
Hi again,
I got a recommendation from Corel support to delete all files connected to my Videostudio X4 Pro and re-install the product.
I did the delete of the files but when inserting the disc for the re-installation I get the start screen but the installation does not start!
Any ideas to solve that problem?
Regards Lars Erik
Hi Erik
You are having your share of problems.
When you uninstalled X4 did you follow these instructions.
There have been some issues with User Accounts
View this post
View this post
lassegus
- ram: 8172 MB
Hi Trevor and thanks for your attention again,
The re-installation problem is solved and I have my X4 installed again but unfortunately the old 3D-problem remains.
No files, my own or the videoclips from X4 are converted to 3D when using that option.
When using another software (Movavi Video Converter 3D) there is no problem to achieve a 3D-version of the files.
Regards Lars Erik
elpibeval
- motherboard: msi k8
- processor: semprom 3000+
- ram: 1.25 GB
- Video Card: ati all in wonder 9600
- sound_card: vinyl ac 97
- Hard_Drive_Capacity: 300
- Monitor/Display Make & Model: synmaster591s
Re: Converting 2D to 3D in VS X4 same problem
I have the same problem when trying to convert a 3D clip the result is white and nothing I have Reintal, Notengo no idea, mine are mpg Capure, please continue to help
thanks
thanks
Hi elpibeval
I will continue to help in any way I can, but as I cannot reproduce the problem I am at a loss as to what to suggest.
In the earlier posts I have suggested everything I can think of and still the problem persists.
Customer support may be the next option to use.
First after creating the 3D file, are you able to play it on your pc using another media player.
Just to summarize……….
1 / Try using the libraries video clips to convert to 3D, do they work?
2 / Reinstall VSX4 to these instructions
3 / Update Direct X, (DirectX Redist (June 2010)
A three part process, download file, run file to extract contents, run DXSETUP.exe
4 / have you installed any extra Codec Packs, these can cause some problems?
Hi lassegus--- elpibeval
Can you e-mail a sample 3D video.
Using the library samples create a 3D video, try to keep it small 5 seconds should do.
View my Quick Guides for my e-mail address.
If I can play the file then Video Studio is creating it correctly.
Are you able to play the files using another media player?
elpibeval
- ram: 1.25 GB
how send the video, 5 seconds and white lol
do not know how to send it thanks
Click the My Quick User Guide –link below
Choose E-Mail Me
Your e-mail editor will open
Attached the 5 second video file, or Insert file, then send.
Choose E-Mail Me
Hello Lars Erik
Thanks for the sample.
It shows as “white” which is I suppose a step forward.
Had I been able to play it then we would assume it is the playback problem, maybe graphic’s driver.
As I cannot play and only see white then it really has to be Video Studio, or something conflicting with the program.
I noticed from the properties that you had created a AVCHD video.
I had been trying standard DVD. I have run through several if not all HD options and cannot reproduce the “white”
I just don’t know what to suggest next other than a complete re-installation of all Corel and Ulead products.
Then purging the pc of all remaining Corel and Ulead files, other than your personal VSP’s that is.
You say you have reported this to Corel, Lets hope that Support comes up with a solution.
elpibeval
- ram: 1.25 GB
reinstall the program and remains the same. so maybe we should wait until corel to do something, can you tell me how to change the option to capture? Templates are only passing you lower field first and says it is better upper
thanks
thanks
