Video Studio X3 - Burn two projects to 1 disc
finchp57
motherboard: GigaByte
processor: Intel
ram: 4GB
Video Card: ATI Radeon HD4600
sound_card: On Board
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Hanon 22"
Post by finchp57 »
I have created two projects within Video Studio X3, which I want to put on one disc as seperate programs, so they can be viewed individually (they are the same subject but covering different time spans) how do I achieve this ?
Re: Video Studio X3 - Burn two projects to 1 disc
The easiest way is to make a separate DVD-compatible mpeg-2 (if you want a DVD) of each project: Share > Create Video File > DVD. Then you simply open MF 7SE (which I hope you have already installed) and insert each new mpeg-2 in the burning timeline. If together they take less than one hour, you are OK. If they are longer, get back to us here...
Post by Trevor Andrew »
Just to add
From DVD Movie Factory 7SE
Select the Options Cogwheel, (lower left) a window will open, the lower section allows you to select the Navigation Controls.
Choosing "Back to Menu" will play the selected video only then return to menu.
otherwise your disc will play forever, and ever, and again.............
