Obviously I am a novice but I am trying to learn so please have patience with me.
How do I remove a small section from the middle of a clip?
RainPure
- motherboard: ELITEGROUP MCP61PM-AM 1.0A
- processor: 3.00 gigahertz AMD Athlon 64 X2 Dual Core
- ram: 3GB
- Video Card: NVIDIA GeForce 6150SE nForce 430 [Display adapter]
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Envision G22LWk (21.7"vis,
How do I remove a small section from the middle of a clip? The help section tells how to shorten a clip or split it in two but not what i want to do.
Re: How do I remove a small section from the middle of a cli
basically you just split the video in two at the start of the piece you want to remove - then split it again at the end of the piece you want to remove - click on the piece you want to remove to highlight it - hit your delete key - and it's gone - do that as often as you like during the length of yur video to remove all the bits you do not want.
remember thaat Videostudio never makes any actual cuts - their all virtual - so if you make a mistake just use the undo icon to step back to make your corrections.
Hi RainPure
This web page was made for VS 8 but the principles of navigating the timeline and cutting a clip haven’t changed.
http://lata.me.uk/video_studio/tutorials/edit/edit.htm
More upto date explaining the blue bar below the preview screen may also be useful
http://lata.me.uk/corel_guide/Blue%20Bar.htm
Its just practice
PS you will not find a more patient bunch of people than here on the forum.
Its just practice
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello RainPure,
Here's another video tutorial that you can follow in removing a clip in the middle of the video.
You can use the Trimming Clips the video is using VS X3 but you can still apply that on VS X4
And the Multi-trim using VS X4.
[vimeo]http://www.vimeo.com/19413810[/vimeo]
If you do not have VS X4 yet, then you can download the trial at http://www.corel.com/trials.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
