Batch conversion
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
Batch conversion
I received a large numer of .cdr (Coreldraw X5) files. I need to batch convert them to .jpg files. Is this possible in Paintshop Pro, or Coreldraw (in my opinion no batch conversion), or is there a specific converter available to do this? Thanks for any advise
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Re: Batch conversion
Well I just looked at PSP X3 and it appears to open CDR files. You could just batch process them to jpegs (I haven't tried to do this).
Click File > Batch Process
You'll get a screen with options. Click browse to find the CDR files and select them.
Put Save Mode to New Type.
Under Type put Jpeg.
You can rename them while this happens too.
Choose a destination folder.
Click Start
You can even run a script on the files if you want.
Click Start
Regards, Dan
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
PSP won't open CDR files produced in CorelDRAW X5. The other problem is that CorelDRAW images is a page based system... the sheet of paper is part of the file.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
somneim
- motherboard: GM880-7Dh2
- processor: AMD x4 Phenom
- Video Card: GTX460
- sound_card: Creative
- Hard_Drive_Capacity: 500
- Monitor/Display Make & Model: Philips
I use FasStone image viewer. It is very light and handy when needed. It has very flexible batch functions for any kind of image file. There is built in batch conversions in Pshop and Bridge but this on FastSTone is much better.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello erdna,
Unfortunately Corel Draw X5 does not have a batch process feature but if you have the full version installed, you should have the MACRO called "CONVERTER.START" that works exactly like a batch process convert.
The CONVERTER.START is self-explanatory, you can locate or run the CONVERTER.START Macro by opening Corel Draw X5, then click on TOOLS > MACROS > RUN MACRO Then in the MACROS IN: select FILECONVERTER (FileConverter.GMS) then select CONVERTER.START, then click on RUN button. You can actually select just the folder where all teh CDR are located and the Macro will automatically search for the files. Then just select the DESTINATION before clicking on the CONVERT button. I did test this and you can actually convert a CDR file to any of the following file format:
AI, BMP. CDR, CGM, CPT, CMX, DSF, DES, DXF, EPS, GIF, JPG, PCT, PNG, PPF, SVG, SWF, TIF, WPG, WMF
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
erdna
- ram: 16GB DDR3
Thx Abel. In the mean time I used the Macro function and converted cdr 250 files to jpg. I finally needed a single pdf file which I created with a virtual pdf writer(W2PDF) out of the converted jpg's.
