Hallo,
I cam from Germany and I hope, you will understand my Question.
I´m working withe PSP X III. Now I have installed the Plugin Knochout 2. I can find this plugin.
When I open a jpg foto an I want to use this plugin, than i get the error message: It a wrong format. Perhaps I have no level.
Perhaps some can explain to me, what I must do.
Sincerely
troedeljahn
plug in Knockout 2.0
troedeljahn
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: plug in Knockout 2.0
Not familiar with the plugin myself. Have you promoted the background layer to a regular raster layer? I'm assuming it needs transparency and the default background layer doesn't have that.
So either duplicate the layer, or promote it to a regular raster layer from the Layer menu.
Of some plugins no longer work properly with X3 because of a change made to the plugin system. I'm not going to tell you that that's what happened, but there is the possibility that the plugin won't work with X3.
troedeljahn
I try´d it. I change to a raster layer, I duplicate the layer, i have open a transparent layer. Nothing works.
Thank you for your answer. I will now install psp x II again and will look, if it works there.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello troedeljahn,
As far as I know KO 2.0 is only compatible with "Microsoft Windows® 98, Windows 2000, Windows NT® 4.0, Windows ME or Windows XP" and may not work with PSP X3.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
troedeljahn
Thank you,
in the offering was also Win 7 mentioned.
By the way, how do you cut your tubes? Do have a plugin, or another program?
Thanks for you beeing.
troedeljahn
Hallo.
Now I ´ve installed PSP X II and the plugin knockout works.
Thanks for your help
troedeljahn
troedeljahn
troedeljahn
Hallo,
Knockout works, but if I want the tube is going back to PSP II, PSP crashed.
Excuse my bad english.
Perhaps you have an idea, how i can cut something out of my photos by a simple way.
Kathy_9
- Hard_Drive_Capacity: 2TB
Have you tried the Object Extractor? It's located under the Image Menu in PSP X3.
troedeljahn
Yes, I´ve tried it. But the results are not so spectacular. There are a lot of things, you must reproduce.
I´ve tried the wand, freehand. that works good, but it is a little difficult if you want cut hairs.
Thanx for you idea
Thanx for you idea
