Have been away for longer than I thought I would be but now back with, hopefuly, some time to pick up my video work.
Came right back to one out of my usual thread.
Am converting a VHS tape to DVD. So captured successfully (albeit with an EzCap device). Produced a fairly good quality AVI file and with no editing at all, used VS x2 to produce my mpeg compatible file. Details of that file are here:
File Format: PAL DVD
File Size: 4,514,938 KB
Duration: 6056.920 Secs
Video Type: MPEG 2 Video, Lower Field First
Totoal Frames: 151,173 frames
Attributes: 24 bits 720 x 576, 16:9
Frame Rate: 25.000 frame/sec.
Data Rate: Variable (Max 6000 kbps)
Audio Type: Dolby Digital Audio
Total Samples 290.252,160 Samples
Attributes: 48000 Hz, 5.1 Channels
Layer: None
Bit Rate 384 kbps
Started a new project, imported the mpeg into the timeline and proceeded to produce my DVD folders. The only custom setting was to reduce the bitrate to 5,000 to get the whole file onto one DVD.
So far so good. Problem is slight out of sync audio towards the middle to end of the DVD. It gets progressively worse as if the audio is at a slightly different frame rate to the video! I have double checked my settings when burning the DVD folders and they are the same as the mpeg except for the bitrate and I have chosen LPCM Audio 48000 Stereo. I tried first with Dolby but that gave the OOS so thought I would try this new setting but the result was the same.
Any guidance would be gratefully received.
BTW A belated Merry Christmas to all
