Westlight
Yes you are understanding that correctly.
For earlier versions of video studio it was a relatively simply job of copying the appropriate library files VS_Video.dat etc
You cannot copy these to the X4 directory, well you can but X4 will give an error.
Also the option to export the X2 libraries does not allow you to import to X4
Video Studio X4 has a completely different library structure.
I have not been able to move my library files as in the old days, that’s technology for you……
The only way I know is described in Ron post, which is as good as any.
Updating from X3 to X4 (Saved content)
Re: Updating from X3 to X4 (Saved content)
FWIW,
I've sent an email to Yvonne Chang, who is one of the managers for VS. I explained this problem, asked if the intended purpose for the Library Export/Import was for backing up, to be useful within the same version, or if it was also to be utilized to migrate libraries from one version to the next. Hopefully I will get a reply that indicates a bug, and they will try to fix it, emphasis placed on Hopefully..
westlight
- motherboard: ASRock 970 Extreme3
- processor: AMD FX-6100 Six Core Processor 4.20 Ghz
- ram: 16 GB
- Video Card: AMD Radeon HD 6700 Series
- Hard_Drive_Capacity: 8000 gb
Thank you for the replies and for passing along the info. I'm sure I'm not the first to consider this to be a minus for upgrading. Giving it a test just the same to see if it's worth upgrading from VS Pro X2.
westlight
www.westlight.net
www.westlight.net
robspa48
- motherboard: AsusTeK P8B75-M
- processor: Intel i7 3770
- Video Card: Intel HD Graphics 4000
- sound_card: VIA HD Audio
- Hard_Drive_Capacity: 2TB+3TB
- Corel programs: CVSX9,CVSX10,CVS 2018, CVS 2022 Ultimate
Is there any news on how to migrate custom libraries (titles, etc) from VS X3 to VS X4?
Roberto
I certainly haven’t heard of any changes…..
You can manually transfer most of the library Samples and Titles from X3 to X4 by adding the library content to the timeline.
Save the project
Open project in X4
Drag clips to library.
You may be best to create a new library page for these clips.
Save the project
Open project in X4
robspa48
Thanks Trevor for this very smart trick to overcome the VS X4 limitations---
Roberto
