Updating from X3 to X4 (Saved content)
less2008
motherboard: ASUS P8P67 LE
processor: Intel i7 2600K
ram: 8 gig
Video Card: Nvidia 8600 gts
sound_card: Realtek Motherboard
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: LG
Post by less2008 »
For anyone who's updated from X3 to X4, did you notice, or can you, keep all your older librarys, transistions, effects, templates, etc. from X3 into X4?
I know in previous updates all installed items did not mirgate to the newer version. Wishfully hoping X4 will migrate from X3 vs another "Fresh" install.
X3, X2 Pro, VS 11.5, C3DPS, Win 7 Pro, Intel i7 2600K, 8 gig sys RAM, XFX GeForce 8600 256mb, 1 tb WD Caviar Black, 2x 1tb separate temp/data file drives, Creative SB 24 bit.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: Updating from X3 to X4 (Saved content)
Post by teknisyan »
Hello less2008,
You can try and export the VS X3 Library then import them on VS X4.
To export your library on VS X3, you can click on SETTINGS > LIBRARY MANAGER > EXPORT LIBRARY.
Then to import the exported library on VS X4, just click on SETTINGS > LIBRARY MANAGER > IMPORT LIBRARY.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Apart from what Abiel has just suggested, X4 is a completely fresh install. It does not overwrite X3 or previous versions, all of which remain fully operational.
Post by Trevor Andrew »
i tried importing X3 library to X4, received error message "files cannot be imported".
Think it may be the new type of library format....................
ragemaker
Post by ragemaker »
I am having trouble with the importing of my X3 Library into my X4. After saving my X3 library I try to import it to my X4 and I get an error message. Files import error: Files can't be imported, maybe number of files is not correct or files are invalidated. Any suggestions?
Thanks,
Eric
Hi Eric
Yes! that’s what I said in my reply.
The library files are called :-
VS_Video.dat
VS_Title.dat
VS_Image.dat
etc
From the exported libraries folders, Try replacing X4’s file with the ones from X3, then import X4.......
However
For XP …The actual library program files can be found here
C:\Documents and Settings\User Name\Application Data\Ulead Systems\Corel VideoStudio Pro\14.0\en-US
You could try replacing the files here.
First make a copy of the relevant library files.
This will work with earlier versions, whether it works with the new X4 library layout……….I haven’t tried.
ragemaker
Post by ragemaker »
I found and replaced the files... and no luck. I guess I will have to recreate all the projects I want to take to x4.
Thanks for the help,
Eric
Hi Eric
Your Projects, the VSP files should open in the re-installed X4.
The library content does not affect the running of the Project (VSP)
ragemaker
Post by ragemaker »
Yes, they do open just fine in X4, it would have just been so much easier for the library to import. Oh well, I will just deal with it, not going to complain a whole bunch as I like the improvements they have made in X4.
Thanks,
Eric
babyleon
motherboard: PEGATRON CORPORATION 2A86 1.04E01
processor: Intel Core i7 930 2.8GHz
ram: 12.0GB
Video Card: ATI Radeon HD 5450
Hard_Drive_Capacity: 7+ TB
Post by babyleon »
Does this mean there is no way to bring X3 libraries into X4? If that is the case, my consideration of going to X4 is decided. My libraries are too important to lose, i.e. I have clips of bird species, filmed over six years, named and organized in a library that I update every year. Without being able to transfer, I would have to review hundreds of hours of video to select those clips again.
The layout of Video Studio library has changed from the earlier version layouts.
X2 /3 uses individual pages for is Video Audio and Sound, selecting each from the drop down panel.
X4 uses a composite single page, you select to hide / show the three options.
Its this framework that cannot be imported.
However the library pages are saved to files in the same way, as I said they are called:-
VS_Video.dat
VS_Title.dat
VS_Image.dat….etc
You should be able to export the library using X2/3 and 4, saving them as a backup.
These folders contain the library files, by replacing the files from X3 to X4 you would effectively be able to import the X3 pages to X4.
In addition the VS_Video.dat type files also reside on the hard drive, I do not know the exact location using W7, But should be able to replace in a similar manner.
I will run a test to confirm I can transfer from X3 to X4.
What actual library pages are you concerned about?
Take care if you look for these files, some are part of the system files (C:\Program Files\Corel ) and are blank library files, the ones you need are under the C:\Documents and Settings\User Name………route
By the way with so many library clips, how do you backup the library???????
PS download the trial of X4 to see the library changes.............. then try transferring the library
Post Edited
I have run a few tests trying to change the library content, Copying file from X3 to X4
Unfortunately I am unable to do this.
The process has worked in the past but the new X4 library seems to be upsetting things. I will continue doing a few more checks.
babyleon
ram: 12.0GB
Post by babyleon »
Thank you for testing this. I will look forward to your final results.
When I installed X3 (formerly using VS11.5+) in my new Windows 7 system, I did the standard install and that put the .dat files in a c:/Users/my user name/AppData/Roaming/Ulead Systems/Corel Video Studio Pro/13.0 folder
which was created in the install process.
I also learned on this Forum several years ago to copy all my .dat files to a different location before installing/upgrading to a new VS version and I am very greatful for that! I was able to transfer them from 11.5+ to X3 with no problem. I would need to transfer them to X4 if I upgrade again. Without that possibility, I would stick with X3. As I have stated previously in several posts, my libraries are very important to me and I use and update them continuously. My continuig wish for VS is that it would allow more than 40 Video libraries.
Thanks again!
Stolman
processor: i-7 2.4GHz
ram: 32GB
Video Card: Std VGA
Monitor/Display Make & Model: DELL 8700
Re: Updating from X3 to X4 (Possible Solution)
Post by Stolman »
I do not have X4 but have just completed a procedure that MIGHT help.
I too have a large X3 library. I backed up my User files (i.e., all files & subfolders in the c:user dir) in addition to doing a system backup. All this in prep for my upgrade from Win7-32 to Win7-64. After the upgrade I found my X3 library files were missing.
After scouring this forum I found your post that advised of restoring the .dat files. This I did for X3 (and also for the trial version of X4 which I later un-installed). Like you found, the results were disappointing. None of my libraries were found. After 3 hours of trial and error, the following solution worked. I have not tried it with X4. I am out of time with deadlines looming but will test in the future and post results unless someone else does so first.
I removed X3 from the PC, using Control Panel AND deleting remaining files in the VSP dir under the C:/User dir. I then reinstalled X3. Before starting it for the first time, I copied ALL the files in the Ulead Video Studio subdir (of the C:/User/Username/Appdata/Roaming subdir) FROM my file-copy backup (NOT the system backup) TO the newly installed Video Studio subdir on my C-drive. I started X3 and my libs were in tact. Saved me WEEKs of re-creating.
Hope this helps.
westlight
motherboard: ASRock 970 Extreme3
processor: AMD FX-6100 Six Core Processor 4.20 Ghz
ram: 16 GB
Video Card: AMD Radeon HD 6700 Series
Hard_Drive_Capacity: 8000 gb
Post by westlight »
So...if I'm understanding this correctly it seems there is no way to just export my library from X2 and then import it into X4? Can the files ie. VS_Video.dat etc. not even be copied and pasted into the new directory created when X4 is installed? This would seem to be a BIG issue for anyone that has a large collection of clips cataloged in previous versions. Hope this is not the case.
westlight
www.westlight.net
About the only way to migrate your, video, audio, photo, and title libraries is by project file (VSP). In VS X3 drag all your video clips from the Video Library onto the video track. Save the project. Open the VSP file in VS X4, create a Library, drag all the clips from the timeline to the Library.
