Greetings
I'm new to VS X3 and I have run into a problem that I can't seem to find the answer to. After trimming and clipping videos, I drag the segments that I want keep into the library. All of the clips that I move into the library have the same name as the original. Is there any way of renaming the trimmed clips?
Naming Clips In VS X3
Re: Naming Clips In VS X3
Just click twice (slowly - as you do when renaming a file or folder in Windows) on the text under the thumbnail in the library - then you can type in any name you like. this only changes the name of the thumbnail - if you are just cutting and moving clips into the library VideoStudio does not actually cut your original video, the thumbnail only points to the selected segment of it, so don't look for actual re-named clips on your computer.
Thank you very much. I feel a bit foolish learning how simple this was but, now I can clean up the mess that I've created in my library.
Again, thank you!
Again, thank you!
