Reverse filter
radarguy
Reverse filter
Post by radarguy »
I cannot seem to locate the reverse filter. Does anyone have a clue why not?
videomartin
Post by videomartin »
What do you mean with reverse filter?
To run a part of a video backwards ?
Mark a clip, right-klick on it and look in the kontext menu for backwars or reverse (don't know which expression is used in the english version).
Sound track should be separated from the video part of the clip before seting the reverse option.
If you will use that only on a part of a clip, you should cut off the required sequence, move it to the desired position, seperate the sound track und set the video track onto reverse.
Same handling is recommended for speed adjustments.
You can make a copy of that clip, too and put it without sound track onto one of the overlay tracks
Hope that helps you.
radarguy
Video reversing
Post by radarguy »
Thanks Martin,
That did help. The manual was calling it a filter but I found the command in the clip pull down menu. Now, how do I delete the audio?
Thanks,
Russ
videomartin
Russ,
thats an easy question.
mark the clip, right-klick it and choose "separate" (or whatever the english command wil be in your version).
Afterwards you mark the audio part and delete it.
