Adjust volume for menu templates
sludge49
- motherboard: Asus P5NSLI
- processor: core 2 duo 2.66 Ghz
- ram: 3Gb
- Video Card: Nvidia Geforce GT220
- sound_card: Asus Xonar DG 5.1
- Hard_Drive_Capacity: 600 Gb
- Monitor/Display Make & Model: EMachines E202H
In the burn stage, after picking a menu template, I cannot adjust the volume of the music for the template. I enter the preview screen and adjust the volume there, using the slider. When I preview the video the volume is where I set it. But when I burn the project the music is back to it's original level, which is very loud. I can select no music, and this works but i can't adjust the volume. Any help would be appreciated.
Re: Adjust volume for menu templates
I do not think there is a way of adjusting the menu volume within the burner module.
The slider you are adjusting is merely changing your PC’s volume control.
The only way I know is to change the volume level on the actual file.
Open VS add the audio clip
Select the clip and open the “options” panel
Reduce the volume 100% adjacent to digital clock to say 40%
Share Create Sound File, will create a Wav of your clip.
PS what version of VS are you using?
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Just to add to what trevor mention... here is the screen shot of the “options” panel and the volume settings that he is saying.
VS X4 VS X3
VS X4 VS X3
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
sludge49
- ram: 3Gb
Thanks guys, your advice solved the problem. Also to answer your question I am using Video Studio 11. Thanks for the help.
