Missing transitions in VSx4 Pro
lpanek
Post by lpanek »
Video Studios 12 Pro had 14 flashback transitions. When upgraded to VS X3 Pro and now to VS X4 Pro noticed that there is only 1 flashback transition. Is there some way to copy the transitions from VS 12 to VS X14 Pro ?
Re: Missing transitions in VSx4 Pro
Welcome to the forums.. :)
If you look at the customization for the Flashback, you'll see they managed to incorporate the majority of those into this single transition thumbnail. Fire up VS X2, drop a couple of images into the time-line, and drag the first Flashback transition (FB1) to the time-line. Now click on the Customize button, and look at the dialog. I promise you that all of those FB transitions in VS X2 are in VS X4...;)
Flashback from VS X2
Flashback fb7 from VS X2
Flashback in VS X4.. Looks very much like the above from VS X2..
lpanek
Post by lpanek »
Thanks !! :D
jrchip01
motherboard: Gateway RS780
processor: 2.50 gigahertz AMD Phenom II X4 805
ram: 8GIG
Video Card: ATI Radeon HD 3200 Graphics
Post by jrchip01 »
(My apologies if this particular problem has been addressed).
I have VSPro X4 14.2.0.23 and can only find 3 transitions. The help file says there are 16. Has anyone else seen this behavior? I put in a support request to Corel - got instructions to remove original installation and download a new version (http://www.corel.com/akdlm/6763/downloa ... bal_PF.exe) and reinstall. This did not solve the problem.
Screenshot of transition screen from my copy of VSPro X4
Help file re:transitions
Best regards,
Chip Scavone
Post by BrianCee »
Your screen shot shows that you only have the "my favorites" library pane open - click on the downward pointing small white arrow next to the words 'my favorites' and a drop down will allow you to access the library panes for many more transitions.
jrchip01
ram: 8GIG
Post by jrchip01 »
BrianCee wrote:Your screen shot shows that you only have the "my favorites" library pane open - click on the downward pointing small white arrow next to the words 'my favorites' and a drop down will allow you to access the library panes for many more transitions.
Brian,
Oops! Many thanks for the tip - glad this forum supports screen shots.
Chip Scavone
