When save a picture the image will be limited
Mowi
- motherboard: ASUS X72V
- processor: intel Core 2 Duo CPU P8400 2.26GHz 2.27GHz
- ram: 4 GB
- Video Card: RICO R5C83x85xFlash Media contrdriver ver.3.55.01
- sound_card: Realtec high definition Audio
- Hard_Drive_Capacity: 140 GB
- Monitor/Display Make & Model: ATI display adapter 0x95C4
When I want to save a picture when I am done I allways get the announcement: Due to the limited file disposition, the file which will be saved will be a limited image. (I am Dutch, so it is a rough translation). How can I avoid this?
I have an other queation:
When I edit my images than they allways become smaller. The go from 4 mb to 200-800Kb. I don't want this but I don't know what to do.
Thank you for your answer.
Ingrid
Ingrid
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: When save a picture the image will be limited
I'm probably going to screw up this explanation but it's pretty simple.
The file format you're saving to, the type of editing you've done, and the settings for the file format you're saving to effects all of the problems you're experiencing.
If you're using layers and want to preserve these layers you need to save to a format that supports layers. PSD (Photoshop Document) and PSPImage formats are ones that support keeping layer information. Best to save in a PSPImage format as that's Paint Shop Pro's default format. The warnings about the file format usually come when you try to save out an image and Paint Shop Pro wants you to know that it's going to essentially perform a "Merge All" function flattening everything and keeping all of the changes before saving the image out. You'll find this with image formats like JPEG or PNG or BMP. Those don't support layers in Paint Shop Pro and so Paint Shop Pro let's you know that it's going to get rid of all of the extra layers and such.
Now the size of the image is a result of compression settings for the file format you're saving into. So let's say that by default you're saving as a JPEG (JPG) file this will give you the warning about flattening the image but because it's a lossy format, and the default settings might be lower than the original image, you'll get a smaller file when Paint Shop Pro tries to save. To change this you have to change your save options.
In the Save dialog there is a button in the bottom right corner of the dialog named "Options" here you can set the compression level for the image. A low compression will result in a larger image size and better quality. A high compression level will result in a smaller image size and lower quality as more information is thrown away to make the image smaller. So go ahead and change the "Compression Factor" down toward highest quality lowest compression. And that should help you out.
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Hi Ingrid,
Can you describe how you save your images to get such a big difference in file size?
You can answer in Dutch if that helps, but my computer Dutch is non-existent (I left Holland 50 years ago), so the answer will most probably be in English
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Mowi
- ram: 4 GB
Joelle wrote:Hi Ingrid,
Joëlle
Beste Joëlle,
Bedankt voor je antwoord. Ik snijd de foto's altijd bij en dan gebeurt het altijd al. Ik heb geen idee hoe ik de kwaliteit dan toch boven de 1 a 2 mb kan houden. Daarnaast wordt de foto ook kleiner als ik hem alleen al bewerk. Gewoon met snellaboratorium, recht maken, vlekjes weghalen etc. Geen grote dingen met lagen. Geen probleem als je in het Engels antwoord, ik ben er altijd blij mee.
Ingrid
Joelle
- ram: 16 GB RAM
Hi Ingrid,
Ik denk dat het antwoord van LeviFiction waarschijnlijk je probleem zal oplossen.
Ik zet die Compression aan 1, alhoewel 6 is ook goed, maar geen hoger nummer dan dat
De beste manier is, (doe ik zelf ALTIJD):
Open je foto. Maak er een duplikaat van, gebruik de key strokes: Shift + D dat is het makkelijkste.
Sluit de originele foto.
Doe dan wat nodig is op de kopie, de originele is dan altijd veilig
Ik hoop dat ik je probleem goed begrepen heb en ook goed uitgelegd heb
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Just FYI,
Since this is an English web board, whenever there are posts using other languages, please post the English translation as well. That way others may also have the benefit from them.
And we may know that you're not plotting to vaporize the planet..
Joelle
- ram: 16 GB RAM
Hehe, you are right, I am not plotting to do anything dastardly.
I mentioned to Ingrid that the explanation offered by LeviFiction was likely her problem.
I also suggested that Ingrid should set her Save compression very low.
I have mine set to 1, although I believe not a lot happens below 6
Then I suggested that Ingrid should always (I do, I am sure many others do) make a dupicate of the original image, close that and work on the duplicate, just to be on the safe side.
As an aside:
One thing I have got out of all of this .. I have discovered that my English comes a lot easier than my Dutch
Joëlle
As an aside:
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Thank you Joelle..
Mowi
- ram: 4 GB
Thank you very much for your reply. I have tried it and the solution was good!! My pictures stay in a larger resolution.
Perhaps until next time and thanks again.
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
Jöelle - Druk op de grote rode knoop om alles te vernietigen!
Just kidding. My knowledge of Dutch only extends to a very few specialised words like Grolsch, Heineken, Amstel...
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
Joelle
- ram: 16 GB RAM
That red button is stuck, but the green one works!
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
