X4 trial Split by Scene - Capture DV-Avi
Re: X4 trial Split by Scene - Capture DV-Avi
Post by Black Lab »
I'm shrinking, I'm shrinking..... :cry:
Post by Trevor Andrew »
Because of the difference in default settings I have always used Make Movie Manager to create my templates and will continue to do so.
It was standard for Digital Video to use Lower field and Analogue to use Upper, till the introduction of HD, oh why didn’t they make HD lower field?
And yes X4 seems to be using Upper as default.
There is of course the Show Messages option that will match the projects to video files.
Guess I’m in a small and shrinking minority as a DV user
Kingstone
I have never used the Wizards to capture my footage, and have to admit I am having trouble finding the Quick Scan option, I have however seen it before, but for the live of me struggling.
What version of VS are you using?
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
Trevor, I'm using VS Pro X4.
"DV Quick Scan" is just below "Capture Video" on the Capture tab.
I call it a bug, because in the past the field order for the video file you were set to create, adopted the filed order of the project and/or video file in your project. So if you had DV, LFF, the MPEG-2 in the Share>Create Video File would also be LFF. Currently it's just stuck at UFF.. ;)
Hi Kingstone
My brain was geared to the Movie Wizards.
Ok I have run a test capture, seems to take longer given that it is called “Quick Scan”
I can see the advantages of being able to select which clips I wish to capture.
The main point is that the “rogue frame” has disappeared.
Now I will capture a full tape to see how it goes.
Big Thanks.
So why does normal DV capture have the problem.
david1939
motherboard: Unknown
Hard_Drive_Capacity: 465GB
Corel programs: VS ultimate 2023,MotionStudio 3D
Post by david1939 »
That's interesting -- I didn't normally use Quick Capture in 10+ (my previous version) because it DID give a "rogue" frame! And so never thought of trying it in X3...
SONY DCR-HC42 Handycam, VideoStudio X4 Pro, X5 Pro, X6 Pro, Motion Studio 3D
david1939
Post by david1939 »
Sorry, that should be "Quick Scan"
I have just tried the Quick Scan method.
Not so quick as the tape is first scanned, then clips captured one at a time.
Lots of movement from the camera as it positions the tape for the next capture.
Capture is however good with no frame issues.
Just takes too long, back to Win DV with the added advantage of naming my captured files.
