VS X3 doesn't encode audio in edited file
kpatch
motherboard: Intel Corporation DG31PR AAD97573-206
processor: 2.00 gigahertz Intel Pentium Dual
ram: 2GB
Video Card: ATI Radeon HD 4600 Series
sound_card: Turtle Beach Riviera
Hard_Drive_Capacity: 500MB
Monitor/Display Make & Model: Dual display: LG W1942 + Panasonic 42" TV
Post by kpatch »
I am having difficulty generating files with VS X3. The app works fine opening the source files, editing and preview playback. Preview replay has audio and is very smooth. However, all generated files have no audio. The files I'm working with are recordings using the Hauppauge HD PVR controlled by BeyondTV (V4.9.2). Those fies are MPEG-2 Transport files, having the extension *.tp. VS does not recognize the TP extension - which is very frustrating. When I change the extension to M2T, they import fine.
Any insight would be greatly appreciated.
DVDDoug
Moderator
Re: VS X3 doesn't encode audio in edited file
Post by DVDDoug »
Try creating an audio-only WAV file, and re-import that audio back into your project. WAV files are generally foolproof... If Video Studio chokes on that task too, try using SUPER (FREE!!!) to extract the audio to WAV.
Did the Hauppauge come with any software for conversion to a different format? (I assume the audio in the M2T file is Dolby AC3, but I don't know why it's causing problems.)
What format are you trying to generate? Is the output-audio stereo or multichannel? (A different output-format probably won't solve the problem... Transcoding problems are usually "from" problems, rather than "to" problems, but it might still be helpful to know where we are going...).
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
I always use a small freeware program called HDTVtoMPEG2 to convert my transport stream .tp files to program stream mpeg, though otherwise still in the same high def format. Always worked for me...
kpatch
ram: 2GB
Post by kpatch »
DVDDoug wrote:Try creating an audio-only WAV file, and re-import that audio back into your project. WAV files are generally foolproof... If Video Studio chokes on that task too, try using SUPER (FREE!!!) to extract the audio to WAV.
Will I run the danger of the audio track being out of sync?
DVDDoug wrote:Did the Hauppauge come with any software for conversion to a different format? (I assume the audio in the M2T file is Dolby AC3, but I don't know why it's causing problems.)
Yes...it came with a conversion app...but seems to be only for mobile devices and gaming consoles. And yes, the audio is Dolby AC3.
DVDDoug wrote:What format are you trying to generate? Is the output-audio stereo or multichannel? (A different output-format probably won't solve the problem... Transcoding problems are usually "from" problems, rather than "to" problems, but it might still be helpful to know where we are going...).
Do I need to transcode first to be able to edit. Can I not just edit the M2T file directly? I have tried to generate many formats...but none of them end up with audio.
kpatch
ram: 2GB
Post by kpatch »
Ken Berry wrote:I always use a small freeware program called HDTVtoMPEG2 to convert my transport stream .tp files to program stream mpeg, though otherwise still in the same high def format. Always worked for me...
Thanks Ken. I'll give it a try.
kpatch
ram: 2GB
Post by kpatch »
Hello Ken:
When I try to add a file in HDTVtoMPEG2, I get the message "WARNING: Could not find a channel!"
Any thoughts?
Sorry, no. I don 't have the computer on which I use HDTVto MPeg2 operating at the moment, but does the program's Help suggest anything?
DVDDoug
Moderator
Post by DVDDoug »
It should stay in sync. But editing might be more difficult, unless you re-combine the video and the "new" audio into a new (different format?) before editing. And, I can't promise that it will stay in sync. Sometimes, the audio & video can go out of sync for no apparent reason, even without extracting the audio... Which is what inspired my "signature" below! :twisted:
You have already old us you can't edit the M2T directly without loosing audio. We are suggesting that your odds are better with a different (or perhaps just a different file or a file encoded with a different encoder.)
Yeah.... That's what I expected... As I said, it's usually a "from" problem... Apparently Video Studio can't convert your file from it's current format (or re-encode to the same format), and you'll have to convert to a different format with a 3rd-party program, or simply find a different video editor that works with your files.
FYI - SUPER can also (hopefully) convert the audio & video to many other formats. I've never used HDTVtoMPEG2, but if you can get it working, I have feeling it's easier to use than SUPER. SUPER has many-many format options... Even their website is confusing... I think you have to click through 3-pages just to get to the program download! :(
No time to think.
Out of... sync.[/i]
