VS PROX4
dpat2000
- motherboard: nVIDIA MCP61
- processor: AMD Athlon 64x2 dual core 5200+ 2.7 GHz
- ram: 4GB
- Video Card: Nvdia GeForce 9400 GT
- Hard_Drive_Capacity: 288 GB
- Monitor/Display Make & Model: Compaq FP7317
VS PROX4
I can not get video fx transitions to show up. I put the VIDEOFX.VFX file into the program folder vfx_plug.
Can anyone help with this.
Thanks Doug
Thanks Doug
Re: VS PROX4
I will try when I can find what I did with Canopus VideoFX... I have not used it now for a couple of versions... But do you have the full program or just that one file?
dpat2000
- ram: 4GB
Re: VS PROX4
yes i have the full program.Ken Berry wrote:I will try when I can find what I did with Canopus VideoFX... I have not used it now for a couple of versions... But do you have the full program or just that one file?
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: VS PROX4
Hello Doug,
Just a thought, did you made sure that you did not hide the video fx? If not make sure you click on the SHOW VIDEO icon, that you see on the screen shot above.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Re: VS PROX4
Abiel -- Canopus VideoFX are in fact transitions. They are installed as a separate program under Canopus, but there is a bridging transition which goes into VS's VFX_Plug folder. You insert that as a transition in a VS project, and it opens the Canopus program to allow you to use one of the Canopus transitions. As such, it is not affected by the Video button you refer to.
dpat2000
- ram: 4GB
Re: VS PROX4
Video fx is a transition plugin not a video. thanks anywayAbiel Corel NA wrote:Hello Doug,
Re: VS PROX4
dpat2000 -- I finally found my disc with the Canopus VideoFX stand-alone program on it. I have installed it, and then added the separate VIDEOFX.VFX to my X4 vfx_plug directory. I opened X4, and then clicked on the Transitions icon. VideoFX now shows up at the bottom of the list.
Sometimes, the list of transitions gets filled with others you may have added, and there seems to be a limit on the number of names that will appear on the drop down list. However, if you press ALL, then VideoFX should also appear then. (Just tested that, and it is there...)
I have also successfully added it to X3 and X2...
dpat2000
- ram: 4GB
Re: VS PROX4
Ken you are a legend it shows up when i click on all but not in the drop down menu.
Hard to believe something simple as that.
Doug
Doug
skyml
- motherboard: Sony VIAO 64bit
- processor: Intel Quad Core i7
- ram: 6GB
- Video Card: NVIDIA Geforce with Cuda
- sound_card: on motherboard
- Hard_Drive_Capacity: 650GB
- Monitor/Display Make & Model: Sony VIAO 17"
Re: VS PROX4
Ken, did I understand correct in that you are able to use your Old Canopus video FX in VS X4? I have the old Xplode effects and a lot of Borris effects that I used to use with MSP 7 (could never get them to work in MSP 8). Is it possible I could get them to work under VS X4???????
Mike Lanfor
www.airplayphoto.com
skyml
- ram: 6GB
Re: VS PROX4
Mike Lanfor
