Default Save-As date
CSM
Post by CSM »
How do I change default when I save-as that it saves as today's date rather than the same data as the image it is copied from?
In X2 it saved as today's date.
Thanks, Carl
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: Default Save-As date
Post by teknisyan »
Hello CSM,
When you use the SAVE AS.. option, you are actually creating a new file, so you it should have the date when you save it. If this was working before and suddenly stopped, you may want to reset your workspace.
You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Reset PSPX3.jpg (24.04 KiB) Viewed 2195 times
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
CSM
Post by CSM »
It does change the date modified and date created, but the "date" still was same as the original. Maybe I just need to look at
the "date modified" column in Windows 7. In X2 it changed the "date" as well as date modified, so X3 seems to behave differently
for this field. I just verified this on my other PC that has X2 installed.
Carl
