Can't import MOV files
VicTorn
motherboard: Dell Inc. 0CRH6C A00
processor: 2.53 gigahertz Intel Xeon
ram: 4GB
Video Card: NVIDIA Quadro FX 580
sound_card: SoundMAX Integrated Digital High Definition Audio
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Viewsonic VP2365wb
Re: Can't import MOV files
Post by VicTorn »
I just ran into the problem of not being able to load a MOV file yesterday and decided to use the suggestion given by "eajhnsn1" (ie. add C:\Program Files (x86)\QuickTime\QTSystem to PATH). I found that it was already in the PATH but as the last entry. I moved it up, just past the Windows O/S entries, then everything worked fine after that.
Ryanclimbs
motherboard: toughbook cf53
processor: intel core 15
ram: 8gb
Video Card: toughbook cf53
sound_card: toughbook cf53
Hard_Drive_Capacity: 750
Monitor/Display Make & Model: toughbook cf53
Post by Ryanclimbs »
WOW!!! THAT WORKS!!!!!!!!!
VX5 .MOV files from Canon DSLR's and latest version of quicktime for my iphone 5!!!!
But again... why can't Corel fix this? So frustrating! I am a same day video editor at weddings and COREL left me glitched out on wedding day... Cost me thousands of dollars
joelbooska
motherboard: hp pavillion dv7
processor: amd quad core phenom p960 180ghz
ram: 4 gb
Video Card: ati radeon
sound_card: stock
Hard_Drive_Capacity: 525 gb
Monitor/Display Make & Model: its a notebook 17.5"
Post by joelbooska »
Hi, thought I'd bump this up. I tried the dll program x86 work around and now my X5 can read and playback MOV files from a Canon EOS7D, lightning fast.
HOWEVER..when I render the video, there are several audio dropouts. I have tried everything.
Taking the original vsp and transferring all vid clips and audio clips to my old laptop and doing a render there with X5, I've uninstalled my asio4all for my music software, and many other efforts.
I notice that with standard def vid clips I have no audio issues after rendering, but for some reason, all my MOV HD projects get blips as if the audio is peaking or clipping or reacting to some of my edits but then again, some of the dropouts are unrelated to any effect or 'cut'..so what gives?
Is it the work around I tried?
Should I uninstall my QT, latest vers. and install the 7.6?
UGH..this software has SUCH potential but after several Corel tech correspondences, I am totally clueless on what to do to fix this.
Adobe Premiere?
JamesRoyal
Post by JamesRoyal »
That worked for me! Thank you for the fix!!!
eajhnsn1 wrote:OK, I found a fix.
Go to your C:\Program Files (x86)\QuickTime\QTSystem directory, copy the QTCF.dll file and paste it into c:\windows.
I'm now able to see QuickTime files and use them in VideoStudio again.
