PSP X reactivation problem - HELP.....
rah
motherboard: ASUSTek P5VD2-VM
processor: Intel Core 2 CPU 4400 2.00GHz 2000
ram: 2.00GB
Video Card: RADEON X550 Secondary
sound_card: SoundMAX HD Audio 0
Hard_Drive_Capacity: 5.00GB
Monitor/Display Make & Model: Dell 1726T-HS/D1025HT
Re: PSP X reactivation problem - HELP.....
Post by rah »
Looking forward to reading the book Joelle...... :roll:
rah
ram: 2.00GB
Re: PSP X reactivation problem - SOLVED.....
Post by rah »
Thanks to Corel Tech Support in Ontario I have finally solved my problem.
If anyone experiences the same problem – that is, finding no place to insert their serial key during a reinstall of PSPX (downloaded version), after assiduously following Corel’s Knowledgebase instructions: “Answer ID 759645 - Activation and Installation Instructions: Paint Shop Pro X” – here is the solution.
1. Do NOT follow the above Knowledgebase advice, instead…
2. When the misleading Trial version splash screen appears during the course of the program installation and before dismissing the screen (which contains in its lower section the words “Already Purchased” with the “A” Underlined), hold ALT and then the A key (on your keyboard) – and the command prompt providing the insertion facility for your serial number will then launch – insert serial number, and you now have a fully functioning program.
Please note that If instead you obtain a screen stating “Sorry, the serial number you are using has already been submitted the maximum number of times for Activation”, you need to contact Corel and have them re-set the count at their end……
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
Brilliant ! :D
Joëlle
(PSPX9 )
