Interpretting Adobe Color Codes
kchildress
ram: 16 Gb
Hard_Drive_Capacity: 2 Tb
Post by kchildress »
... back again trying to interpret Photoshop lingo
What exactly does this mean in terms of color codes? #FFFF7F, #FFE5CC, #7F7F7F (as a few examples)
Can this be converted to PSP actions?
Re: Interpretting Adobe Color Codes
Those are HTML color codes, used for the web. For example the first code in your example is also R-255; G-255; B-127 (which is RGB), or HSL would be, H-42; S-255; L-191.
I used third code you provided "#7F7F7F" color code here. When you're posting to the web board, click on the Font Color button. Then clicking on a color swatch will insert the proper code, part of that being the HTML color code.
kchildress
ram: 16 Gb
Ron,
I see. But I think I'm missing something ...
I don't understand how you knew "#7F7F7F" was an option in the group of color swatches. Or did you just paste that code into the text box and the color magically appeared in your text?
Lastly, how did you convert the HTML color code into an RGB measure?
Sorry if I'm missing something obvious.
Thanks!
Kevin
Look in the Materials Properties dialog..
kchildress
ram: 16 Gb
Got it!
kchildress
ram: 16 Gb
one more question ...
So once I have the RGB and HSL values, what is the quickest/easiest way to apply those to a layer? The only way I know is to write each of the values down and manually adjust the RGB and HSL values individually. Any way to copy/paste those values in one wide stroke?
EDITED with idea: Apparently I don't know how to apply an exact RGB and HSL mix to a layer. Looks like I'm adding a blank layer, filling it with a given color code, changing that blend mode to COLOR and merging down????
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Hello kchildress,
That will depend on what result you want to have. But if you want to know how the best way to apply the RGB or HSL is just apply each value to the MATERIALS Properties from the screen shot of Ron.
This is the best time to practice your use of the Num Pad and the TAB key.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
