Hello,
How do I align/rotate a still image on the overlay track using Corel Pro x2. and is it possible to place text on the still image?
Windows XP H/P t650uk
2 Gbt memory
80Gb hard drive
Thank you
Align a still image on the overlay track
jaysto
- motherboard: Acer Aspire X1420
- processor: 2.80 gigahertz AMD Athlon II X2 220
- ram: 4GB
- Video Card: NVIDIA GeForce 6150SE
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Acer AL1916W
Re: Align a still image on the overlay track
To align and / or rotate an image, click on the Edit tab;
To place text over an image, simply add your text/title to the title track, immediately below the image. The stacking order in VS is backwards. The Main video track is the lowest layer, all the tracks beneath the Main video track, are above it..
jaysto
- ram: 4GB
Thank you Ron,
What i meant by aligning was can it be done by degrees. What i have is a still picture that includes a large mirror this picture is on the video track, what I wanted to do was to align the picture on the overlay track by degrees to the shape of the mirror,I have a feeling that this is not possible with Video studio.
Once again thank you for your help.
Jaysto
You're correct, rotation can only be done in 90deg increments. However you can distort an image, by grabbing and dragging the small green handles, which are found just to the inside of the yellow handles on each corner.
jaysto
- ram: 4GB
\Thank you Ron re the above.
I have a further question that i hope you can answer, I am creating a slide show using ProX 2 many of the slides are in portrait format. What I would like to do is have two slides side by side on the time line and in their original shape. I have done a search but cannot find any body having tried this.
Thank you
jaysto
Thank you
jaysto
Jaysto
You can do this by using the main video track and an overlay track, or 2 overlay tracks. If you place one photo in the main video track, you need to click on the Attribute tab, check the box beside Distort clip, then on the Preview window, drag the image to one side. Now for the photo in the overlay track, you need to resize it, as it comes in at ¼ it's original size. Right-click on it in the preview window and select Original size. Now drag it to the other side of the preview window.
If you want to get a little fancy, use 2 overlay tracks, then have each of them enter from their respective sides. You'll find these on the Attribute panel.
jaysto
- ram: 4GB
Two portrait pictures on the video track
Thank you Ron
Two portrait shots on the video track this looks very nice in the preview window and works well
jaysto
jaysto
Jaysto
