I have paint shop Pro photo X3 with all the updates installed. Only a few of the plugins I have installed show. They are installed in the plugin folder, all the dll files are installed. Any suggestions...it seems the ones like eye candy, and Filters unlimited show but the simple 8bf files do not. Any suggestions?
I am using xp pro, 2gb memory.
Plugins do not show in X3
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Plugins do not show in X3
Hello ndhamby,
If you where able to use or install these plugin on PSP X3 before then it can any of the 3.
The plugin is not properly installed. Make sure the plugin is properly installed by checking where you got the plugin.
The Plugin is not enabled and to enable plug-ins
1. Choose File Preferences File Locations. The File Locations dialog box appears.
2. From the File types list, select Plug-ins.
3. Mark the Enable plug-ins check box.
The plugin location was not add properly.
3. Click Add. A new blank item appears in the folder list, and the Browse for Folder dialog box appears.
4. Navigate to the folder you want to add, and click OK to return to the File Locations dialog box.
5. In the Folder options dialog box, mark the Enable check box.
6. Click OK.
6. Click OK.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
