How to select all video clips then set audio same level
gaardmand
motherboard: Gigabyte H67MA-D2H
processor: Intel i5-2400
ram: 4GB
Video Card: Onboard
sound_card: Onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Acer V233H
Post by gaardmand »
Hi.I'm sorry to bring this topic up again, but I can't seem to find the answers in any of the previous ones.
I have several movieclips I want to turn the volumen down to the same level. I don´t want to do it one clip at a time. When I select multible clips, the soundlevelbar turns gray and I can´t change the level.
Please advise
Thanks, Gaardmand
Re: How to select all video clips then set audio same level
Post by Black Lab »
You can't do it in VS. You would have to export the project's audio (Share>Create Sound File) and adjust the sound in a sound editor, then import it back into VS.
What you might be able to do, and I say might because I have not tried it, is to use an audio filter to adjust the volume, rather than using the clip volume controls (the audio would have to be in the music or voice tracks to apply audio filters). You then might be able to right click on the audio clip and choose "copy attributes". If so you can then "paste attributes" to the rest of the clips, thereby speeding up the process a bit. This process would probably only apply to X3.
gaardmand
ram: 4GB
Video Card: Onboard
sound_card: Onboard
Post by gaardmand »
Hi Jeff.
Thanks for your reply.
I haved tried to copy attributes, but when I want to paste it - nothing happens. (I don't even get an errormessage)
I shame the X3 doesn't support this simple feature...
Thanks again.
/Gaardmand
Post by Black Lab »
I agree. But keep in mind that VS is a primarily a video editor, and has never been a strong audio editor. I think that can be said about many video editors. Although I must say I don't know why that is, because audio is so important to most video productions. :?
