The Audio and some Video are "stuttering"
I know that with MOV files you can convert to MP4 and get around it...
I have tried to convert the MTS files to MP2 but no success...
Anyone have an easy fix for me!
Thanks!
J.J.
To change the Smart proxy settings, please follow these steps.The main purpose of the Smart Proxy feature is to have a more fluid editing experience when working with large, high resolution video files.
When you edit and preview your project, proxy files will be used as substitutes for their large video source counterparts. Whereas when you render a video file, the original video source files will be used.
Proxy files are lower resolution working copies of video files. They are reduced in resolution or compression bit rate -- to speed up editing of high definition files such as HDV and AVCHD. Proxy files are source-dependent rather than project-dependent. In other words, proxy files can be shared among different projects. Smart Proxy can also be used with other video file formats and is not limited to HD files.
