Hi.
My partner has been having a problem with the gif-x 2 plugin.
So far the main problem is with the 'scan' effect. It worked, and now it doesn't.
The 'scan' effect just repeats the same frame, with the scan light beam stuck on the left. Nothing was changed. it just stopped working.
Any ideas how to fix this?
All the other effects still work though.
Gif-X making me angry. Effects stop working.
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Are you sure nothing was changed?
On the Key Frame control, set the slider all the way to the left. Make note of the value in the position field. The default is 0.
Now drag the Key Frame slider all the way to the right. What is the value of the position field now? The default is 100.
Also, on Key Frame control, how many frames is set there? It should be at least 2. Default is 15.
If the position values are the same on the first key frame and the last key frame, then change one of them.
