Create from AVCHD files miss audio with Smart Render
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
I tested yesterday creating a video using "same as first video". All inserted files were AVCHD. The created video file, typed mpg, was missing audio no matter what I tried: tried mp4, avi, etc. I then turned off Smart Render in the options that pop-up when creating the video and it worked ( I have Smart Render turned off in the Preferences, BTW). This appears to be a bug or am I doing something wrong? In any case I am happy with this "work-around" Al
User for more than 10 years.
Re: Create from AVCHD files miss audio with Smart Render
Hi Al
I have yet to move into the HD video world, but the forums HD users do recommend disabling Smart Render when using HD
Its not a new thing, In the past if problems have occurred with standard video, we would try without Smart Render.
Unfortunately we don’t know why there is sometimes a problem, the mysteries of video editing.
As it doesn’t happen to all, I doubt if its recognised as a bug.
Moreover, 'Same as first video' does not work properly with HD video (whether HDV or AVCHD). If you get anything, it is usually SD mpeg-2...
- aljimenez
- ram: 24GB
Thanks for pointing this prior knowledge that somehow escaped me. I thought I had Smart Render turned off since it is turned off in the Preferences. However, it was ticked on when Creating/Rendering the file. I had to tick it off again in the Options button when creating the file.trevor andrew wrote: .... users do recommend disabling Smart Render when using HD
So this is a recognized bug? Is there a "List of bugs" and workarounds somewhere?Ken Berry wrote:Moreover, 'Same as first video' does not work properly with HD video (whether HDV or AVCHD). If you get anything, it is usually SD mpeg-2...
Al
Not that I've seen, unfortunately...Is there a "List of bugs" and workarounds somewhere?
Not sure you can turn off Smart Render from preferences. Maybe I'm missing something?
You are not getting confused with Smart Proxy, are you?
- aljimenez
- ram: 24GB
Well, all this smart stuff have made me dumb! I think you are right... Altrevor andrew wrote:You are not getting confused with Smart Proxy, are you?
