Due to Choppy Video and stuttering Audio in Videostudio pro X3, I read in the users forum that the cause was the VS Pro3 service pack 3 and that there was no patch fix.
The only way to overcome the problem was to uninstal Pro X3 and reinstal without applying the patches.
Have done this and the problem is now fixed, however I notice that my bundled Movie Factory 7 (which came with X3 has disapeared ???
Have downloaded the trial version so that I can finish my project but this only has a 30 day trial, after which I need to purchase it !
As I have already paid for this software is there any way I can reinstal it from my original X3 disc, or from the Corel website ??
Any help gratefully appreciated.
Lishmann
Lost Movie Factory 7
Re: Lost Movie Factory 7
So you are saying it installed when you first installed X3, but did not install when you re-installed X3?
Jeff
Dentler's Dog Training, LLC
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello Lishmann,
The VS X3 includes DVD Movie Factory 7 SE which is free and you can download the free DVD Movie factory 7 SE by follow these steps.
1. Start VideoStudio Pro X3 and choose the Advanced Edit mode.
2. In the top right-hand corner of the screen, click on the Help and Product Information icon. It looks like an arrow in a circle.
3. A window will appear. Click on the icon that looks like a gear wheel and choose the option "Check for Updates".
4. Up to 4 updates may be found. Choose to install all the updates and then close VideoStudio Pro X3.
5. Once the updates have been installed, start VideoStudio Pro X3.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Lishmann
- motherboard: Asustech
- processor: 3.00 Gig Pentium 4
- ram: 1536mb
- Video Card: Radeon X1650
- sound_card: SoundMax
- Hard_Drive_Capacity: 160.04 gb
Hi and thanks for your reply, yes so I have now uninstalled and re installed. I think that when I initially uninstalled, the program did not completely remove DVD factory 7, so I removed it manually and it has now correctly re-installed..
Only problem now is that Videostudio pro X3 keeps freezing when I search through captured clips using either the jog slider or the timeline control..
Have increased memory to 2gb and installed a 1tb hard drive, but still have the problem. Unless I can get it sorted I will have to find another program to use as I cannot afford the time to waste on this.
Cheers
Lishmann
Cheers
Lishmann
Lishmann
- ram: 1536mb
Hi and many thanks for your reply.
Have recovered movie factory 7 se so thanks again for the info.
Am now suffering with X3 freezing when I search using either timeline or preview window.
There seems to be a lot of Hard Drive access during the freezes which can last for 10mins !! When the program recovers I only have to move the jog slider a small amount for it to freeze again... lasting several more minutes.
Do you know if this is a problem anyone else has experienced or if there is a patch ?
Cheers
Lishmann
Cheers
Lishmann
No, no one else has reported this sort of behaviour. But can you please explain exactly what you mean by "...when I search using either timeline or preview window"?
Hard drive activity can be from a multitude of things, not related to the program being used at the time. With the current windows versions, there's what's called pre-fetch activity. The program along with the OS, is guessing based on your activity, what files you may need next. So it will seek, find, and hold those files for immediate access, which is what helps increase speed. It could also be a service or process that is running in the background. Some image editing programs have cataloging features, these can run in the background, as well as Windows own indexing service.
One library that VS X3 has, is the Windows Media Library option. There are 2 sub-menus, video library and picture library. These will scan your system for those files. and will greatly slow things down. If you have chosen one of them, you may find that doing anything else until it has completed, will be difficult. Once I discovered this, I've learned to avoid them.
Lishmann
- ram: 1536mb
Hello and thanks again for your reply.
I am compiling educational movies based on various film clips that I reasearch and capture, from both online and available dvd sources.
I capture the chapter that I need and insert it into the timeline, then scroll through to get to the actual clip that I want to use.
Whilst scrolling through a chapter Pro X3 freezes. This can last for 10-15mins and the program is unusable at this time. A large amount of Hard Drive activity is happening, not on the working folder drive, but on Drive C where Windows is installed.
The problem has become so bad that I have had to revert back to my old Ulead Videostudio 10 plus which does not suffer with this problem.
Hope this helps explain my problem.
Many thanks
Lishmann
Many thanks
Lishmann
