I purchased Windvd Pro 2010 online from Corel.com and installed it yesterday. When I start the program, I get a popup which says "Product installation unsuccessful, please reinstall the software. Error Code=1". I have tried reinstalling multiple times - also followed instructions from this forum on a related thread to remove WinDVD manually by deleting registry keys - it did not help. Interestingly - I do not even see the following keys in regedit (under Wow6432Node - there's only an NVIDA key available - there isn't even a SOFTWARE level present):
# My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SOFTWARE\Corel\DVD10
# My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SOFTWARE\Corel\PCU\
# My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Software\Microsoft\Windows\CurrentVersion\Uninstall\5C1F18D2-F6B7-4242-B803-B5A78648185B
Another point -- I tried to install the patches -- tried Service Patch 1 - and it fails during install saying it could not find Windvd installed on the system.
Any suggestions on how to fix this issue?
mrcotton73.
Windvd Pro 2010 - Error Code=1 on starting program
Moderator: lata
mrcotton73
- motherboard: DP35DP
- processor: Intel Core2 Quad CPU Q9450 2.66GHz
- ram: 2GB
- Video Card: EVGA NVIDIA GeForce GT 220
- sound_card: on board sound
- Hard_Drive_Capacity: 160gb
JeffRandall
- motherboard: Sony VGX-XL3
- processor: Intel
- ram: 2GB
- Video Card: Nvidia
- sound_card: built-in
- Hard_Drive_Capacity: 750GB
Re: Windvd Pro 2010 - Error Code=1 on starting program
Have you tried installing with Run as Administrator?
nepenthe
- motherboard: Gigabyte GA-P55A-UD3P
- processor: i-7 860
- ram: 16 GB
- Video Card: Gigabyte GeForce GTX 470 SOC
- sound_card: onboard Realtec audio
- Hard_Drive_Capacity: 600 GB
- Monitor/Display Make & Model: NEC MultiSync EA192M
mrcotton73 -
Something is interfering with Windows Installer. Are you running anti-virus software? If so, I would recommend disabling your anti-virus software (be sure the service is stopped in the Task Manager) and re-attempting installation.
nepenthe
nepenthe
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Hello mrcotton73,
You may want to manually remove the WinDVD 2010 then reinstall the program from the download link or the disc.
Answer ID 764253 - How to manually remove Corel WinDVD 2010 (Standard or Pro)?
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
mrcotton73
- ram: 2GB
Thanks for the replies.
To Abiel -- I did try that (see my initial post -- I deleted registry keys and manually deleted the folders) and reinstalled -- did not work.
I am pretty sure my account has Admin privilege but I didn't try running as Administrator -- so I will try that - and also will try disabling Kaspersky in services (though I think I did kill Kaspersky at one point when reinstalling). I will try these tonight and post back.
mrcotton73
mrcotton73
mrcotton73
- ram: 2GB
OK - I tried reinstalling by selecting "Run as administrator" - did not work either.
I must mention that I manually deleted the previous installation again, did a search through the registry and manually deleted all keys / values I could find and then reinstalled -- and still no luck.
mrcotton73
mrcotton73
petea
- motherboard: assus
- processor: Intel i7
- ram: 6gb
- Video Card: NVidia
- Monitor/Display Make & Model: sony
Just purchased this software & expeirienced same problem several times. I am using AVG virus protection. I had to disable the Resident Shield portion of the protection to allow the program to operate. You may try disabling your virus protection to install. This fixed my problem. Good Luck
I have the same problem. could you solve the problem ? is there any solution ? i deactivated my virus protection too and reinstalled windvd. no success.
alfredog1976
- motherboard: EVGA X79 FTW
- processor: i7 3930K
- ram: 32GB
- Video Card: GeForce Titan
- sound_card: Onboard
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Acer 22"
For those still having issues, make sure to uninstall WinDVD Pro 2010 and install using the following:
http://bit.ly/XcvBQE
Then install Service Pack 7 using following link:
http://bit.ly/Zq5T5x
You should then be good to go. I was having similar issue as OP as patches would not detect WinDVD Pro 2010 install. My guess is the original installer was the trial version and had issues related to reinstallation.
