PSP X in compatibility mode (Windows 7)...
thumper300zx
Post by thumper300zx »
I run PSP X successfully in Windows 7, but I have a couple problems...
1) It will only display the DEFAULT printer (I have three printers I use from PSP X).
2) I can't install patches ("the upgrade patch cannot be installed....")
Any help? (an upgrade to PSP X3 is a solution I'd prefer to avoid if possible).
Thanks.
thumper300zx
Re: PSP X in compatibility mode (Windows 7)...
I was able to install two updates by switching to the ADMINISTRATOR account, but had to start with 2 then 3 (it wouldn't let me install the first patch). I had tried installing the updates from a 'user' account 'as administrator' but that didn't work.
After the patches, the printer problem is the same, but hey, I have the updates in, and it's still working. That's the most important part. But still would like to get all printers show up.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
As well as the patches that you've installed there is one more. (http://corel.custhelp.com/app/answers/d ... _id/760272). It will update you to 10.10, which will fix some Vista/7 compatibility issues... but unfortunately not the missing "Printers" button from the Print dialogue box.
I haven't heard of any solution to that. The only workaround is to temporarily change the Windows default printer. There are utilities which allow you to quickly change default printers from a system tray icon. One from Microsoft, which dates back to Windows 2000 but runs fine with newer versions, is described at http://www.watchingthenet.com/change-de ... ndows.html.
Tim Morrison
C-Tech Volunteer
thumper300zx
Tim Morrison wrote:As well as the patches that you've installed there is one more. (http://corel.custhelp.com/app/answers/d ... _id/760272). It will update you to 10.10, which will fix some Vista/7 compatibility issues... but unfortunately not the missing "Printers" button from the Print dialogue box.
Thanks for that.
I went ahead and purchased X3.
