Audio filters missing in Videostudio X3
Heesenproductions
- motherboard: ASUS P5Q-EM
- processor: Intel Core2 Quad Q6600 2.40 GHz
- ram: 6GB
- Video Card: NVIDIA GeForce 9600 GT
- sound_card: Realtek High Definition Audio onboard
- Hard_Drive_Capacity: 1500GB
- Monitor/Display Make & Model: Philips 192E [Monitor] (18.5")
I have a problem with the audio of one of my video projects. During the actual video shooting, the microphone had acoustic problems and it is heard on the recorded clips. I had split the audio from the video and want to use some audio filters on it to see if it helps, but the audio filters choice on the clip menu is greyed out. Does someone know how I can enable the audio filters
Sony DCR-SR100E HDD Camcorder recording in SD MPEG2 VBR9100, Upper Field first, 720 x 576, 16:9, Dolby Digital 5.1 Bit rate 448kbps
Sony HDR-XR200 HDD Handycam recording HD1080 recording in AVCHD, setting up to record in SD MPEG2 VBR9100 Dolby Digital 5.1
Re: Audio filters missing in Videostudio X3
You do have the audio clip selected ? If so you should see the yellow handles on the ends, and there is a thin yellow border (top and bottom).
Heesenproductions
- ram: 6GB
Yes, I do have the audio clip selected. The audio filters are also greyed out in the music & voice tab options.
Maybe it’s the video type that VS just does not like, what are the properties of your video file?
Are you able to apply Audio Filters to the VS Sample audio clips.
Or
Try creating a Sound File – Add to music track, are you able to apply audio filters?
If you can create a sound file, then try Audacity to edit your sound file.
Or
